Case Insensitive Path {{include}}
Is there any way for me to have something like:
<div id="content">
  {{include "templates/myname.html"}}
</div>
Then let’s say I have:
templates/
 - MyName.html
Any way for it to include a file, in a case insensitive way?
Not if you’re on a case-sensitive filesystem. If you’re on Windows then that would probably work fine, but not on linux/mac.
Hmm alright, I have an easy solution so it’s no problem. It’d just be a tiny bit easier if the case insensitive file loading was possible. But I understand the issue, because what would one do in the case of:
templates/
  - MyName.html
  - myName.html
  - myname.html
so that’s fair.
I suggest making your tooling ensure that all files are all lowercase, or something.
