I can’t get reverse_proxy to work. It seems to redirect to itself rather than to the host I specify. I have replaced my domain with “example” for privacy, and as you can see I have a .com for the load balancer and a .org for the backend. The loadbalancer is api.example.com and the backend host is kb01.example.org. I’m including only the information on the loadbalancer since I get no traffic whatsoever arriving to kb01. As you can see in the logs in the loadbalancer, no the redirect is pointing to itself and no attempt is made to redirect to kb01.
root@lb:~# cat /etc/caddy/Caddyfile
api.example.com {
reverse_proxy kb01.example.org
root@lb:~# caddy reload --config /etc/caddy/Caddyfile
2024/05/10 16:55:37.523 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": ""}
root@lb:~# curl -vL https://api.example.com
* Trying 149.202.34.249:443...
* Connected to api.example.com (149.202.34.249) port 443 (#0)
* ALPN: offers h2,http/1.1
* CApath: /etc/ssl/certs
* ALPN: server accepted h2
* subject: CN=api.example.com
* start date: May 9 09:33:01 2024 GMT
* expire date: Aug 7 09:33:00 2024 GMT
* subjectAltName: host "api.example.com" matched cert's "api.example.com"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* using HTTP/2
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: api.example.com]
* h2h3 [user-agent: curl/7.88.1]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x563731a94c80)
> GET / HTTP/2
> Host: api.example.com
> accept: */*
< HTTP/2 308
< date: Fri, 10 May 2024 16:56:21 GMT
< location: https://api.example.com/
< server: Caddy
< server: Caddy
< content-length: 0
* Connection #0 to host api.example.com left intact
* Issue another request to this URL: 'https://api.example.com/'
* Found bundle for host: 0x563731a8e0a0 [can multiplex]
* Re-using existing connection #0 with host api.example.com
* h2h3 [:path: /]
* Using Stream ID: 3 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 5 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 7 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 9 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 11 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 13 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 15 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 17 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 19 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 21 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 23 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 25 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 27 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 29 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 31 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 33 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 35 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< date: Fri, 10 May 2024 16:56:22 GMT
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 37 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 39 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 41 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 43 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 45 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 47 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 49 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 51 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 53 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 55 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 57 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 59 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 61 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 63 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 65 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 67 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 69 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 71 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 73 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 75 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 77 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 79 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 81 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 83 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 85 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 87 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 89 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 91 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 93 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 95 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 97 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 99 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* h2h3 [:path: /]
* Using Stream ID: 101 (easy handle 0x563731a94c80)
> GET / HTTP/2
> accept: */*
< HTTP/2 308
< server: Caddy
< server: Caddy
< content-length: 0
* Maximum (50) redirects followed
curl: (47) Maximum (50) redirects followed
sudo apt update
sudo apt install caddy
Debian 12. The output of uname -a:
Linux lb 6.1.0-21-cloud-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.90-1 (2024-05-03) x86_64 GNU/Linux
api.example.com {
