): 2.2.0
2. How I run Caddy: service file called by systemctl start
a. System environment: vps on ubuntu 18.04.5 with xcaddy compiled caddy version
sudo systemctl start caddy
taken directly from https://github.com/caddyserver/dist/blob/master/init/caddy.service
there are a lot of other sites in here which are working, but it says not to redact anything.
auto_https disable_redirects
https://eiphax.tech {
header / {
Strict-Transport-Security "max-age=31536000; includeSubdomains; preload"
X-Frame-Options "DENY"
root * /var/www/eipdox
try_files {path} {path}.html
dns digitalocean token redacted
https://facts.eiphax.tech {
header / {
root * /var/www/eipdox/facts
https://soultrader.net.au {
header / {
root * /var/www/st
php_fastcgi unix//var/run/php/php7.4-fpm.sock
https://blog.eiphax.tech {
header / {
root * /var/www/blog
try_files {path} {path}/ /index.php?{query}&p={path}
https://album.eiphax.tech {
header / {
root * /var/www/lychee/public
https://bin.eiphax.tech {
header / {
root * /var/www/eipbin
https://3ds.eiphax.tech {
header / {
root * /var/www/eipdox/3ds
https://tinydb.eiphax.tech {
header / {
root * /var/www/eipdox/tinydb
http://wiiu.eiphax.tech:80 {
root * /var/www/eipdox/wiiu
output file /var/log/access.log {
roll_size 1gb
roll_keep 5
roll_keep_for 720h
https://nx.eiphax.tech {
header / {
root * /var/www/eipdox/nx
https://nintendohomebrew.com {
header / {
root * /var/www/eipdox/nh
https://bhax.nintendohomebrew.com {
header / {
root * /var/www/bhax/web/nbhax
protocols tls1.2 tls1.2
https://bfm.nintendohomebrew.com {
header / {
root * /var/www/eipdox/nh/seed
reverse_proxy localhost:8082
http://part1dumper.nintendohomebrew.com {
reverse_proxy localhost:8081
https://shitpost.lol {
header / {
root * /var/www/sp
https://hacc.me https://please.hacc.me {
header / {
root * /var/www/hacc
https://friigaemsworld.com {
header / {
root * /var/www/frigam
https://uwu.tax {
header / {
root * /var/www/uwu
https://conversation.id {
header / {
root * /var/www/conv
trying to serve wiiu.eiphax.tech on http, and everything else on https
wiiu.eiphax.tech still seems to be redirecting to https even though 1. http is explicitly specified 2. http auto redirect is turned off
although logging is enabled, it doesn’t seem to output to an actual log file.
i did manage to get this from sudo systemctl status caddy:
Sep 27 02:26:56 eiphax.tech caddy[18946]: {"level":"info","ts":1601173616.9546394,"logger":"http.log.access","msg":"handled request","request":{"remote_addr":"74.125.212.46:51454","proto":"HTTP/1.1","method":"GET","host":"3ds.eiphax.tech","uri":"/favicon.ico","headers":{"Connection":["keep-alive"],"Accept":["image/*"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/49.0.2623.75 Safari/537.36 Google Favicon"],"Accept-Encoding":["gzip,deflate,br"],"X-Forwarded-For":["98.174.197.88"]}},"common_log":"74.125.212.46 - - [27/Sep/2020:02:26:56 +0000] \"GET /favicon.ico HTTP/1.1\" 0 0","duration":0.000008092,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
unfortunately my knowledge in this field is somewhat limited, as i dont usually need to disable https.
