Guiz
(Guillaume Bouzige)
June 6, 2020, 8:30am
#1
1. Caddy version (v2):
add repo fury
debian apt install caddy
debian raspbian
sudo service caddy restart
paste full file contents here
I am trying to configure dokuwiki with caddyserver.
I found this example :
If anyone can advise
I managed to adapt it to v2 a bit but I am stuck with the last one :
#rewrite {
if {path} not_match /lib/.*
if {path} not_match /forbidden
r /(.*)
to {uri} /doku.php?id={1}&{query}
Those ones I transforms without error when lauching the service but still hasn’t got any wiki running
php_fastcgi / unix//var/run/php-fpm/php-fpm.sock
rewrite /(data/|conf/|bin/|inc/|install.php) /forbidden
rewrite /_media(. ) /lib/exe/fetch.php?media={1}
rewrite /_detail(. ) /lib/exe/detail.php?media={1}
rewrite / export/([^/]+)/(. ) /doku.php?do=export* {1}&id={2}
Thanks !!
Hi @Guiz , welcome to the Caddy community!
Your configs are a bit hard to read. Would you mind editing your post to set your configs as preformatted text? You can select the whole config and then click this button in the editor:
Alternately, you can start and end your code blocks with triple backticks on their own lines (```).
I note also that the matchers you’re using are exact, but you’ve got regex characters in there. Matchers don’t support regex syntax; you’ll need to use a named matcher for that: Request matchers (Caddyfile) — Caddy Documentation
kunago
(Miroslav Abrahám)
June 22, 2020, 7:20am
#3
I am using this configuration and all seems to work.
root * /srv/{host}
php_fastcgi localhost:9000
encode zstd gzip
@restrict_files {
path /data/* /conf/* /bin/* /inc/* /vendor/* /install.php
@allow_media {
path /_media*
@allow_detail {
path /_detail*
@allow_export {
path /_export*
path_regexp export /([^/]+)/(.*)
respond @restrict_files 404
rewrite @allow_media /lib/exe/fetch.php?media={path}
rewrite @allow_detail /lib/exe/detail.php?media={path}
rewrite @allow_export /doku.php?do=export_{http.regexp.export.1}&id={http.regexp.export.2}
try_files {path} {path}/ /doku.php?id={path}&{query}
I so far have not had a problem.
system
(system)
closed
July 6, 2020, 8:30am
#4
