Hi,
I use the abiosoft/caddy docker container and after seeing that a new release of caddy was available wanted to rebuild to take advantage of any fixes. Unfortunately, the build fails do to a missing function in the Cloudflare provider:
# github.com/caddyserver/dnsproviders/cloudflare
../../../caddyserver/dnsproviders/cloudflare/cloudflare.go:27:10: undefined: "github.com/xenolf/lego/providers/dns/cloudflare".NewDNSProviderCredentials
Is anyone else able to replicate this error or is this a “just me” problem? Looking at the latest master in the cloudflare.go source file I don’t see this function defined.
Relevant snippet from docker compose file:
build:
context: github.com/abiosoft/caddy-docker.git
args:
- plugins=cloudflare,realip,cache,expires,ipfilter,git,cors
hostname: caddy
command: --conf /etc/Caddyfile --log /var/logs/caddy.log --agree=true
cap_add:
- NET_ADMIN
dockernet:
ipv4_address: 172.31.220.4
- ${DOCKER_SVC}/caddy/data/Caddyfile:/etc/Caddyfile
- ${DOCKER_SVC}/caddy/data/.caddy:/root/.caddy
- ${DOCKER_SVC}/caddy/data/logs:/var/logs
- ${DOCKER_SVC}/caddy/data/www:/srv
ulimits:
nofile:
soft: 64000
hard: 64000
labels:
- com.centurylinklabs.watchtower.enable=false
- TZ=${TZ}
- PUID=${PUID}
- PGID=${PGID}
- CADDYPATH=/root/.caddy
- ACME_AGREE=true
- CLOUDFLARE_EMAIL=${CLOUDFLARE_EMAIL}
- CLOUDFLARE_API_KEY=${CLOUDFLARE_API_KEY}
- LOG_LONG="[{when}] {remote} {hostname} | {scheme} {method} | {host} | {uri} | {rewrite_uri} | {status} {latency} {size} | {>X-Forwarded-For} {>X-Forwarded-Proto} {>X-Dest-Ip}"
