fpfle
(fpfle)
1
If have installed Caddy with an easy config but every time when I start Caddy it will not bind to port 80 or 443.
It always start on port 2015.
The output when I start Caddy is:
Activating privacy features… done.
http://:2015
I have already tried to use this command:
setcap cap_net_bind_service=+ep ./caddy
But I don’t know how to configure Iptables described in the FAQ.
I have running a Ubuntu 16.04 Vps.
Can you post the contents of your Caddyfile and the command you use to start Caddy?
fpfle
(fpfle)
3
This is the Caddy file:
root@flemming-petersen ~/caddy# cat conf.Caddyfile
flemming-petersen.de {
root /root/caddy
This is the command I use to start Caddy
root@flemming-petersen ~/caddy# ./caddy
http://:2015
matt
(Matt Holt)
4
You need to specify the Caddyfile to use:
./caddy -conf conf.Caddyfile
By default, Caddy looks for a file called “Caddyfile” in the cwd.
fpfle
(fpfle)
5
nice now it works thank you very much
system
(system)
Closed
6
