Can someone help me with a rewrite?
Can someone help me with this nginx rewrite to convert it over to Caddy?
# You may add here your
# server {
# statements for each of your virtual hosts to this file
# You should look at the following URL's in order to grasp a solid understanding
# of Nginx configuration files in order to fully unleash the power of Nginx.
# http://wiki.nginx.org/Pitfalls
# http://wiki.nginx.org/QuickStart
# http://wiki.nginx.org/Configuration
# Generally, you will want to move this file somewhere, and start with a clean
# file but keep this around for reference. Or just disable in sites-enabled.
# Please see /usr/share/doc/nginx-doc/examples/ for more detailed examples.
server {
	listen 80;
	listen [::]:80;
	root /var/www;
	index index.php index.html;
	# Make site accessible from http://localhost/
	server_name localhost;
	location / {
		# First attempt to serve request as file, then
		# as directory, then fall back to displaying a 404.
		try_files $uri $uri/ /index.php?$args;
		# Uncomment to enable naxsi on this location
		# include /etc/nginx/naxsi.rules
	location ~ \.php$ {
                try_files $uri = 404;
                fastcgi_pass 127.0.0.1:9000;
                fastcgi_index index.php;
                include fastcgi_params;
	error_page 404 /404.php;
Any help is appreciated, thanks!
    localhost:80 {
        root /var/www
        fastcgi / 127.0.0.1:9000 php
        errors {
            404 404.php
        rewrite {
            to {path} {path}/ /index.php?{path}&{query}{fragment}
Thanks for your help @Robert! That looks good. :+1:
The try_files might need a rewrite but I guess that depends on the PHP application.
Oops. Added the rewrite part to my previous answer
But beware: At least apache (don’t know about nginx) handles leading slashes differently to caddy
See: Another .htaccess conversion problem with rewrites
