1. Output of caddy version
postmarketOS edge aarch64 (Alpine Linux)
rc-service caddy reload
#!/sbin/openrc-run
supervisor=supervise-daemon
name="Caddy web server"
description="Fast, multi-platform web server with automatic HTTPS"
description_checkconfig="Check configuration"
description_reload="Reload configuration without downtime"
: ${caddy_opts:="--config /etc/caddy/Caddyfile --adapter caddyfile"}
command=/usr/sbin/caddy
command_args="run $caddy_opts"
command_user=luan:luan
extra_commands="checkconfig"
extra_started_commands="reload"
depend() {
need net localmount
after firewall
checkconfig() {
ebegin "Checking configuration for $name"
su ${command_user%:*} -s /bin/sh -c "$command validate $caddy_opts"
eend $?
reload() {
ebegin "Reloading $name"
su ${command_user%:*} -s /bin/sh -c "$command reload $caddy_opts"
eend $?
stop_pre() {
if [ "$RC_CMD" = restart ]; then
checkconfig || return $?
fi
None
I can’t reload or restart the caddy
* Reloading Caddy web server ...
SIGILL: illegal instruction
PC=0x545390 m=0 sigcode=1
instruction bytes: 0x0 0x6 0x38 0xd5 0xe0 0x7 0x0 0xf9 0xc0 0x3 0x5f 0xd6 0x0 0x0 0x0 0x0
goroutine 1 [running, locked to thread]:
golang.org/x/sys/cpu.getisar0()
golang.org/x/sys@v0.0.0-20220728004956-3c1f35247d10/cpu/cpu_arm64.s:14 fp=0x4000157290 sp=0x4000157290 pc=0x545390
golang.org/x/sys/cpu.readARM64Registers()
golang.org/x/sys@v0.0.0-20220728004956-3c1f35247d10/cpu/cpu_arm64.go:65 +0x2c fp=0x40001572d0 sp=0x4000157290 pc=0x544c1c
golang.org/x/sys/cpu.doinit()
golang.org/x/sys@v0.0.0-20220728004956-3c1f35247d10/cpu/cpu_linux_arm64.go:38 +0x24 fp=0x40001572e0 sp=0x40001572d0 pc=0x544f04
golang.org/x/sys/cpu.archInit(...)
golang.org/x/sys@v0.0.0-20220728004956-3c1f35247d10/cpu/cpu_arm64.go:45
golang.org/x/sys/cpu.init.0()
golang.org/x/sys@v0.0.0-20220728004956-3c1f35247d10/cpu/cpu.go:199 +0x20 fp=0x40001572f0 sp=0x40001572e0 pc=0x5442a0
runtime.doInit(0x24caf40)
runtime/proc.go:6329 +0x128 fp=0x4000157430 sp=0x40001572f0 pc=0x59d28
runtime.doInit(0x24de2e0)
runtime/proc.go:6306 +0x68 fp=0x4000157570 sp=0x4000157430 pc=0x59c68
runtime.doInit(0x24cac80)
runtime/proc.go:6306 +0x68 fp=0x40001576b0 sp=0x4000157570 pc=0x59c68
runtime.doInit(0x24c9480)
runtime/proc.go:6306 +0x68 fp=0x40001577f0 sp=0x40001576b0 pc=0x59c68
runtime.doInit(0x24d73c0)
runtime/proc.go:6306 +0x68 fp=0x4000157930 sp=0x40001577f0 pc=0x59c68
runtime.doInit(0x24ce060)
runtime/proc.go:6306 +0x68 fp=0x4000157a70 sp=0x4000157930 pc=0x59c68
runtime.doInit(0x24dce00)
runtime/proc.go:6306 +0x68 fp=0x4000157bb0 sp=0x4000157a70 pc=0x59c68
runtime.doInit(0x24e00a0)
runtime/proc.go:6306 +0x68 fp=0x4000157cf0 sp=0x4000157bb0 pc=0x59c68
runtime.doInit(0x24dcf40)
runtime/proc.go:6306 +0x68 fp=0x4000157e30 sp=0x4000157cf0 pc=0x59c68
runtime.doInit(0x24c6f40)
runtime/proc.go:6306 +0x68 fp=0x4000157f70 sp=0x4000157e30 pc=0x59c68
runtime.main()
runtime/proc.go:233 +0x1f8 fp=0x4000157fd0 sp=0x4000157f70 pc=0x4bc88
runtime.goexit()
runtime/asm_arm64.s:1172 +0x4 fp=0x4000157fd0 sp=0x4000157fd0 pc=0x7da84
goroutine 2 [force gc (idle)]:
runtime.gopark(0x0?, 0x0?, 0x0?, 0x0?, 0x0?)
runtime/proc.go:363 +0xe4 fp=0x4000068fa0 sp=0x4000068f80 pc=0x4c0b4
runtime.goparkunlock(...)
runtime/proc.go:369
runtime.forcegchelper()
runtime/proc.go:302 +0xb4 fp=0x4000068fd0 sp=0x4000068fa0 pc=0x4bf44
runtime.goexit()
runtime/asm_arm64.s:1172 +0x4 fp=0x4000068fd0 sp=0x4000068fd0 pc=0x7da84
created by runtime.init.6
runtime/proc.go:290 +0x24
goroutine 3 [GC sweep wait]:
runtime/proc.go:363 +0xe4 fp=0x4000069770 sp=0x4000069750 pc=0x4c0b4
runtime/proc.go:369
runtime.bgsweep(0x0?)
runtime/mgcsweep.go:278 +0xa4 fp=0x40000697b0 sp=0x4000069770 pc=0x36824
runtime.gcenable.func1()
runtime/mgc.go:178 +0x28 fp=0x40000697d0 sp=0x40000697b0 pc=0x2ac78
runtime.goexit()
runtime/asm_arm64.s:1172 +0x4 fp=0x40000697d0 sp=0x40000697d0 pc=0x7da84
created by runtime.gcenable
runtime/mgc.go:178 +0x70
goroutine 4 [GC scavenge wait]:
runtime.gopark(0x4000090000?, 0x18e2588?, 0x1?, 0x0?, 0x0?)
runtime/proc.go:363 +0xe4 fp=0x4000069f50 sp=0x4000069f30 pc=0x4c0b4
runtime/proc.go:369
runtime.(*scavengerState).park(0x2581260)
runtime/mgcscavenge.go:389 +0x5c fp=0x4000069f80 sp=0x4000069f50 pc=0x3481c
runtime.bgscavenge(0x0?)
runtime/mgcscavenge.go:617 +0x44 fp=0x4000069fb0 sp=0x4000069f80 pc=0x34d84
runtime.gcenable.func2()
runtime/mgc.go:179 +0x28 fp=0x4000069fd0 sp=0x4000069fb0 pc=0x2ac18
runtime.goexit()
runtime/asm_arm64.s:1172 +0x4 fp=0x4000069fd0 sp=0x4000069fd0 pc=0x7da84
runtime/mgc.go:179 +0xb4
goroutine 17 [finalizer wait]:
runtime.gopark(0x40000685a8?, 0x600000000266a8?, 0x38?, 0xef?, 0x1?)
runtime/proc.go:363 +0xe4 fp=0x4000068580 sp=0x4000068560 pc=0x4c0b4
runtime/proc.go:369
runtime.runfinq()
runtime/mfinal.go:180 +0x128 fp=0x40000687d0 sp=0x4000068580 pc=0x29e98
runtime.goexit()
runtime/asm_arm64.s:1172 +0x4 fp=0x40000687d0 sp=0x40000687d0 pc=0x7da84
created by runtime.createfing
runtime/mfinal.go:157 +0x94
r0 0x1
r1 0x400009e090
r2 0x0
r3 0x18ebac0
r4 0x400009e090
r5 0x0
r6 0x1
r7 0x0
r8 0x0
r9 0x30
r10 0x400009e090
r11 0x30
r12 0x0
r13 0x18e1d53
r14 0x400009e0bf
r15 0x1000
r16 0x40001543a0
r17 0xa
r18 0x0
r19 0xd0
r20 0x40001571b0
r21 0x40001579d8
r22 0x4000004000
r23 0x0
r24 0xffffffffffffffff
r25 0x16700a0
r26 0x24caf78
r27 0x25b2986
r28 0x40000021a0
r29 0x4000157288
lr 0x544c1c
sp 0x4000157290
pc 0x545390
fault 0x0
Rebuild caddy with xcaddy
