Do I need to set anything special so Caddy will know how to manage this share folder between servers?
Thanks
Thanks
I don’t believe so. EFS behaves like a regular file system to the OS, right?
Caddy clustering works automatically when sharing a CADDYPATH
on a file system.
You may want to set the CADDY_UUID_FILE
for each server, though, or that’ll get shared between the lot of them too: https://caddyserver.com/docs/cli#caddy-uuid-file
I read the explain but I still don’t understand it. If I don’t set it what will happen?
If it’s not set, every clustered Caddy instance will share the same UUID instead of having their own individual UUIDs.
These UUIDs are used for statistics (telemetry). You may or may not be concerned with that.
