Can I have Local and Remote Reverse Proxy using the same Caddy Instance?
I am trying to reverse proxy an internal site with both a local DNS record and a Cloudflare Zero-Trust tunnel external access.
I have a local DNS entry that points records.myhost.com to 10.0.0.200
  • When I do NOT have a Cloudflare DNS entry pointing at the tunnel, I can locally access records.myhost.com securely
  • When I HAVE a Cloudflare DNS entry pointing at the tunnel I can remotely access records.myhost.com securely, but local access is broken (ERR_SSL_PROTOCOL_ERROR)
Is it even possible to do this with 1 Caddy instance?
I probably need to enable higher logging, right now the log only contains info messages about ACME renewals
Caddy version 2.8.4, docker image built ~9months ago with xcaddy and Cloudflare
RUN xcaddy build --with github.com/caddy-dns/cloudflare
FROM caddy:latest
Docker on Unraid.
Caddyfile:
records.myhost.com {
		dns cloudflare {env.CF_API_TOKEN}
	reverse_proxy http://10.0.0.200:8000 {
	    header_down Referrer-Policy "strict-origin-when-cross-origin"
