): 2.4.6
Debian packages linked at Install — Caddy Documentation
Debian 11.2
sudo systemctl start caddy
The one from the package
not relevant at this time…
I want to implement TLS terminating reverse proxy for rsyncd but can’t find anything relevant in the documentation or forums. The reverse_proxy directive supports two transports, http and fastcgi, but this isn’t either of those.
The man page rsyncd.conf(5) describes how to do this with nginx under SSL/TLS Daemon Setup:
An example nginx proxy setup is as follows:
stream {
server {
listen 874 ssl;
listen [::]:874 ssl;
ssl_certificate /etc/letsencrypt/example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/example.com/privkey.pem;
proxy_pass localhost:873;
proxy_protocol on; # Requires "proxy protocol = true"
proxy_timeout 1m;
proxy_connect_timeout 5s;
Is this possible with Caddy? Is it worth filing a feature request (is this something the Caddy project would be interested in supporting)?
