Caddyfile works with :80 but not mydomain?
Hi good people!
Long time Linux user, First time Caddy user.
I intend to use Caddy as reverse proxy to point to a small number of Docker containers running on my self-hosted server.
Initially, trying to configure Caddy using my domain from Cloudflare (to which I’ll refer as mydomain.com).
Cloudflare (A record) is configured, confirmed by reaching my page via mydomain.com when Caddyfile is left at :80.
My page is reachable from LAN, WAN and via curl when Caddyfile is left at :80, but when I change Caddyfile from :80 to mydomain.com as per instructions, it stops working (error below).
Please advise?
Error from web browser:
The page isn’t redirecting properly
Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
This problem can sometimes be caused by disabling or refusing to accept cookies.
Curl mydomain.com returns nothing when Caddyfile is pointed at mydomain, returns properly when Caddyfile is pointed at :80.
v2.9.1
Linux raspberrypi 6.6.74+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.74-1+rpt1 (2025-01-27) aarch64 GNU/Linux
sudo apt update
sudo apt install caddy
Directly (systemctl service) as default after installation.
Version that doesn’t work:
mydomain.com {
respond "Website under construction"
Version that does work:
Is your Cloudflare configuration orange cloud or grey cloud?
Orange (proxied), so after your comment I tried grey (non-proxied) and it works!
However, Cloudflare’s proxy protection is nice to have, is there a way to get it working together?
I don’t use Cloudflare, so I’m not familiar with it, but is this similar to what you’re trying to do?
https://community.cloudflare.com/t/force-http-between-cloudflare-and-server/28390
