I need to maintain an service that use caddy v1.
I would love to update this to v2.
It has a simple Caddyfile → still i struggle with the rewrite rules on this.
V1:
localhost:8080
root /var/www/ev_content/offlinemode
rewrite {
if {path} not_match ^/api
if {path} not_match ^/img
to {path} {path}/ /
what i have done for V2 sofar:
localhost:8080
root * /var/www/ev_content/offlinemode
rewrite not path /api/* /
rewrite not path /img/* /
im struggeling with the rewrite rules / its not working …
what is wrong? im blind ?
So what this is saying is “define a matcher called @tryfiles which matches when the path does not start with either /api or /img, AND when there is a file on disk that is either at {path} or {path}/ (for a directory) or /index.html (which should always exist)” – the file matcher here is a tautology, it will always match, but it does one important thing, and that’s populate the {http.matchers.file.relative} placeholder which is the path which it actually found on disk.
As an aside, you’ll notice there’s a try_files directive which does much the same thing, but we’re not using it here because it’s a shortcut for a matcher + a rewrite, it doesn’t support another matcher on it.
