2.1.1
Linux - Manjaro KDE
Docker 19.03
docker run --rm -it \
--name caddytest \
-p 80:80 -p 443:443 \
-v $PWD/public:/usr/share/caddy/ \
-v $PWD/caddy/data:/data \
-v $PWD/caddy/Caddyfile:/etc/caddy/Caddyfile \
-v $PWD/caddy/tls:/tls caddy
N/A
pugs.localhost {
tls /tls/pugs.localhost.pem /tls/pugs.localhost-key.pem
root * /usr/share/caddy
auto_https
behavior according to docs should implicitly be off
for the given site block when providing a local certificate.
Unlike tls internal
(which fails to generate a certificate from auto_https off
), as a certificate can be found when visiting the site address there is no TLS error. However redirects from HTTP to HTTPS should not happen implicitly according to the docs?
I am ok with the redirect, but is this the intended behavior contrary to what the docs suggest should happen? auto_https off
or auto_https disable_redirects
will explicitly disable the implicit redirects globally to all site blocks as expected, this was presumably meant to happen on the given site block implicitly? (but seems to have no effect if so)
2020/09/09 07:49:30.437 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": "caddyfile"}
2020/09/09 07:49:30.439 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2020/09/09 07:49:30 [INFO][cache:0xc00003b8c0] Started certificate maintenance routine
2020/09/09 07:49:30 [WARNING] Stapling OCSP: no OCSP stapling for [pugs.localhost]: no OCSP server specified in certificate
2020/09/09 07:49:30.439 INFO http skipping automatic certificate management because one or more matching certificates are already loaded {"domain": "pugs.localhost", "server_name": "srv0"}
2020/09/09 07:49:30.439 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2020/09/09 07:49:30.439 INFO tls cleaned up storage units
2020/09/09 07:49:30.440 INFO autosaved config {"file": "/config/caddy/autosave.json"}
2020/09/09 07:49:30.440 INFO serving initial configuration
- Using the JSON API for
ignore_loaded_certificates: false
does not disable either (assuming this is manually loading) - Differs from
tls internal
withauto_https off
as the certificate is still provided.
<cert_file> and <key_file> are the paths to the certificate and private key PEM files. Specifying just one is invalid; specifying both will disable automatic HTTPS.
Related issue raised on Github for docs (no response for 3 weeks):
https://github.com/caddyserver/website/issues/79
