when I try my container (there is a caddy server and a react frontend) locally with localhost:80 , I have no problem but in K8S under an ingress ( aws load balancer ) I have a problem :
I can curl from internet the pod
curl https://mywebsite.io/project_A/
BUT it show an empty page ( blank )
and the firefox console show errors
GET
https://mywebsite.io.io/static/js/main.acbe4637.js
[HTTP/2 503 Service Unavailable 4ms]
GET
https://mywebsite.io.io/static/css/main.acb135df.css
Loading failed for the <script> with source “https://mywebsite.io.io/static/js/main.acbe4637.js”. behavior:1:460
GET
https://mywebsite.io.io/logo192.png
[HTTP/2 503 Service Unavailable 0ms]
GET
https://mywebsite.io.io/favicon.ico
but if I manually curl the https://mywebsite.io/project_A/logo192.png it work ( show the react logo )
so all the urls are missing the prefix_path , how can I solve this ? thank you
no error in the logs of the container
using the docker image caddy:alpine
EKS 1.26
no custom of the entrypoint of the caddy:alpine container
auto_https disable_redirects
handle_path /api/* {
reverse_proxy {$BACKEND_API_HOSTNAME}:{$BACKEND_API_PORT} {
header_up X-Real-IP {remote_addr}
rewrite * /project_A/{uri}
root * /usr/share/caddy/
try_files {path} {file} /index.html
it look like that the line
is incorrect or not working , thank you for the help
