v2.3.0
I want to run Caddy as a sidecar container to Hugo
Docker
caddy run --config /config/caddy-conf
"logging": {
"log": {
"output": "file",
"filename": "access.log",
"roll_size_mb": 20,
"level": "DEBUG"
I want to run Caddy mainly as a log emitter, so I’ve been experimenting with configs (one of the examples is above, but I also tried some other options). However, I feel like documentation is not too clear on that and I keep running into different error messages regarding the parsing of my config. Maybe it’s a bit of a noob question, and I’m sorry if it is, but I’m desperate. My goal is only to get logs from a site served by Hugo. I’ve had experience with Nginx as a sidecar container before but wanted to try out Caddy. The goal is: get access logs as pages visited, searches performed, maybe load time of pages (if possible), so mostly around the usage of the site. Thank you in advance.
run: loading initial config: loading new config: json: unknown field "log"
I’ve seen some other options like
level debug
just debug and some other replacement and playing around with spacing, newlines, format, etc.
