asrob
(Peter Borsa)
November 7, 2023, 2:31pm
1
There is no specific problem so far, I would like to get help to convert the following nginx config file to Caddy v2 format: Drupal | NGINX
location = /favicon.ico {
log_not_found off;
access_log off;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
# Very rarely should these ever be accessed outside of your lan
location ~* \.(txt|log)$ {
allow 192.168.0.0/16;
deny all;
location ~ \..*/.*\.php$ {
return 403;
location ~ ^/sites/.*/private/ {
return 403;
# Block access to scripts in site files directory
location ~ ^/sites/[^/]+/files/.*\.php$ {
deny all;
# Allow "Well-Known URIs" as per RFC 5785
location ~* ^/.well-known/ {
allow all;
# Block access to "hidden" files and directories whose names begin with a
# period. This includes directories used by version control systems such
# as Subversion or Git to store control files.
location ~ (^|/)\. {
return 403;
location / {
try_files $uri /index.php?$query_string;
location @rewrite {
rewrite ^ /index.php;
# Don't allow direct access to PHP files in the vendor directory.
location ~ /vendor/.*\.php$ {
deny all;
return 404;
# Protect files and directories from prying eyes.
location ~* \.(engine|inc|install|make|module|profile|po|sh|.*sql|theme|twig|tpl(\.php)?|xtmpl|yml)(~|\.sw[op]|\.bak|\.orig|\.save)?$|^(\.(?!well-known).*|Entries.*|Repository|Root|Tag|Template|composer\.(json|lock)|web\.config)$|^#.*#$|\.php(~|\.sw[op]|\.bak|\.orig|\.save)$ {
deny all;
return 404;
location ~ \.php(/|$) {
fastcgi_split_path_info ^(.+?\.php)(|/.*)$;
try_files $fastcgi_script_name =404;
include fastcgi_params;
fastcgi_param HTTP_PROXY "";
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param PATH_INFO $fastcgi_path_info;
fastcgi_param QUERY_STRING $query_string;
fastcgi_intercept_errors on;
# PHP socket location.
fastcgi_pass unix:/var/run/php/php-fpm.sock;
location ~* \.(js|css|png|jpg|jpeg|gif|ico|svg)$ {
try_files $uri @rewrite;
expires max;
log_not_found off;
# Fighting with Styles? This little gem is amazing.
location ~ ^/sites/.*/files/(css|js|styles)/ {
# Handle private files through Drupal. Private file's path can come
# with a language prefix.
location ~ ^(/[a-z\-]+)?/system/files/ {
# Enforce clean URLs
# Removes index.php from urls like www.example.com/index.php/my-page --> www.example.com/my-page
# Could be done with 301 for permanent or other redirect codes.
if ($request_uri ~* "^(.*/)index\.php/(.*)") {
return 307 $1$2;
brew install caddy
MacOS Sonoma 14.1 (23B74) (Apple Silicon CPU / arm64)
brew services start caddy
(ssl) {
tls /opt/homebrew/etc/nginx/_wildcard.local.test+4.pem /opt/homebrew/etc/nginx/_wildcard.local.test+4-key.pem
(phpfpm) {
encode zstd gzip
php_fastcgi unix//tmp/php-fpm.sock
(cache-static) {
@static {
file
path *.avif *.css *.eot *.gif *.gz *.ico *.jpg *.jpeg *.js *.otf *.pdf *.png *.svg *.ttf *.webp *.woff *.woff2
header @static Cache-Control "max-age=31536000,public,immutable"
(drupal-10) {
root * "/Users/asrob/Sites/{http.request.host.labels.2}/www"
import ssl
import phpfpm
import cache-static
drupal10.local.test {
import drupal-10
What part isn’t working? Please elaborate.
asrob
(Peter Borsa)
November 8, 2023, 6:52am
3
Well, I’ve tested my config based on nginx one, here is the current Caddyfile:
(ssl) {
(php-socket) {
encode zstd gzip
(drupal) {
import ssl
import php-socket
@hiddenFilesRegexp {
path_regexp (^|/)\.
respond @hiddenFilesRegexp 403
@hiddenPhpFilesRegexp {
path_regexp \..*/.*\.php$
respond @hiddenPhpFilesRegexp 403
@notfoundPhpFiles {
path /vendor/.*\.php$
respond @notfoundPhpFiles 404
@notfoundPhpFilesRegexp {
path_regexp ^/sites/[^/]+/files/.*\.php$
respond @notfoundPhpFilesRegexp 404
@privateDirRegexp {
path_regexp ^/sites/.*/private/
respond @privateDirRegexp 403
@protectedFilesRegexp {
path_regexp \.(engine|inc|install|make|module|profile|po|sh|.*sql|theme|twig|tpl(\.php)?|xtmpl|yml)(~|\.sw[op]|\.bak|\.orig|\.save)?$|^(\.(?!well-known).*|Entries.*|Repository|Root|Tag|Template|composer\.(json|lock)|web\.config)$|^#.*#$|\.php(~|\.sw[op]|\.bak|\.orig|\.save)$
respond protectedFilesRegexp 404
@static {
file
handle / {
try_files {path} /index.php?{query}
rewrite * /index.php
drupal-10.local.test {
import drupal
I’m not sure how I implement the following:
location ~ ^/sites/.*/files/(css|js|)styles/ {
return 307 $1$2;
Or do I skip these because Caddy handles it correctly?
asrob
(Peter Borsa)
November 8, 2023, 7:07am
4
I’ve just updated my Caddyfile:
(ssl) {
(php-socket) {
encode zstd gzip
(drupal) {
import ssl
import php-socket
path_regexp (^|/)\.
@notfoundPhpFiles {
@privateDirRegexp {
@static {
file
handle / {
@cssJsStyles path_regexp ^/sites/.*/files/(css|js|styles)/
handle @cssJsStyles {
@privateFiles path_regexp ^(/[a-z\-]+)?/system/files/
handle @privateFiles {
import drupal
I tried to implement the rules that I mentioned my previous comment. Caddy is running, no errors in log file but I’m not sure my Caddyfile is good and secure enough or there are bad practices.
I would be grateful if you can review my Caddyfile and provide feedback. Thanks in advance!
This doesn’t so anything useful at all, because php_fastcgi
already has try_files
built in. You can remove all handle
which have only try_files
and rewrite
like that because they’re ineffective.
You can simplify these by making the matcher a one-liner:
@hiddenFilesRegexp path_regexp (^|/)\.
Also, you might consider using error
instead of respond
, which allows you to use handle_errors
to respond with a custom error page in a unified way.
You can just use tls internal
instead, and Caddy will generate a TLS cert of its own. You can add Caddy’s CA to your system’s trust store when testing locally. Very simple.
asrob
(Peter Borsa)
November 8, 2023, 9:35am
6
Thank you very much! I’ve done that you suggested, it works well so far.
system
(system)
Closed
December 8, 2023, 9:35am
7
