2.3.0
Caddy is installed as a service with caddyfile in /etc/caddy
Caddy is supposed to proxy the output (Port 8888) of a dockerd Nextcloud instance to https/Port 443 with a self-signed cert for testing.
Debian 10.7 (running as a VM) with a dockerd Nextcloud setup,
Caddy is installed as a systemd service directly (not dockerd) on the docker host.
The VM has a fixed local IP in my LAN.
Windows 10 client
service caddy start
nc-test.hfw18 {
encode gzip zstd
tls internal
reverse_proxy 127.0.0.1:8888
output file /var/log/caddy_nc.log
# enable HSTS
I’m trying to access the Nextcloud page on port 443, but Firefox/Chromium keep throwing ssl error “SSL_ERROR_INTERNAL_ERROR_ALERT”. Connecting directly to the Nextcloud on port 8888 is not a problem.
Do I have to worry about the sudo errors (see pasted output of ‘service caddy status’) when running Caddy as a systemd service?
Output of ‘service caddy status’:
Jan 20 09:08:16 debian-docker caddy[1384]: 2021/01/20 09:08:16 define JAVA_HOME environment variable to use the Java trust
Jan 20 09:08:16 debian-docker sudo[1392]: pam_unix(sudo:auth): conversation failed
Jan 20 09:08:16 debian-docker sudo[1392]: pam_unix(sudo:auth): auth could not identify password for [caddy]
Jan 20 09:08:16 debian-docker sudo[1392]: caddy : user NOT in sudoers ; TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/tee /usr/local/share/ca-certificates/Caddy_Local_Authority_-_2021_ECC_Root_260085191920187754335991439435632523912.crt
Jan 20 09:08:16 debian-docker caddy[1384]: {“level”:“error”,“ts”:1611130096.5906372,“logger”:“pki.ca.local”,“msg”:“failed to install root certificate”,“error”:“failed to execute sudo: exit status 1”,“certificate_file”:“storage:pki/authorities/local/root.crt”}
Jan 20 09:08:16 debian-docker caddy[1384]: {“level”:“info”,“ts”:1611130096.5909111,“logger”:“http”,“msg”:“enabling automatic TLS certificate management”,“domains”:[“nc-test.hfw18”]}
Jan 20 09:08:16 debian-docker caddy[1384]: {“level”:“warn”,“ts”:1611130096.591306,“logger”:“tls”,“msg”:“stapling OCSP”,“error”:“no OCSP stapling for [nc-test.hfw18]: no OCSP server specified in certificate”}
Jan 20 09:08:16 debian-docker caddy[1384]: {“level”:“info”,“ts”:1611130096.5914094,“logger”:“tls”,“msg”:“cleaned up storage units”}
Jan 20 09:08:16 debian-docker caddy[1384]: {“level”:“info”,“ts”:1611130096.5918684,“msg”:“autosaved config”,“file”:"/var/lib/caddy/.config/caddy/autosave.json"}
Jan 20 09:08:16 debian-docker caddy[1384]: {“level”:“info”,“ts”:1611130096.5921562,“msg”:“serving initial configuration”}
Already successfully did a ‘sudo caddy trust’ and imported the Caddy root.crt from /var/lib/caddy/.local/share/caddy/pki/authorities/local/root.crt into my Windows 10 client. Restarted the client and browsers.
Lots of posts here about reverse-proxy problems. Mostly related to missing certificate on connecting client…
