): Caddy 2
2. How I run Caddy: using a systemd service file
Proxmox LXC containerb. Command:
none
Description=Caddy Web Server
After=network.target
User=http
Group=http
ExecStart=/usr/bin/caddy run --config /etc/caddy/caddy.json --environ
ExecReload=/usr/bin/caddy reload --config /etc/caddy/caddy.json
# Hardening options
ProtectSystem=strict
PrivateDevices=true
ProtectHome=true
ReadWritePaths=/var/lib/caddy /var/log/caddy
NoNewPrivileges=true
ProtectKernelTunables=true
ProtectKernelModules=true
ProtectControlGroups=true
LockPersonality=true
d. My complete Caddyfile or JSON config: nextcloud related config
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "reverse_proxy",
"upstreams": [
"dial": "10.10.10.230:80"
"match": [
"host": [
"cloud.myshinydomain.com"
"terminal": true
I use caddy2 as a reverse proxy to various services including my nextcloud container. My nextcloud instance is giving warnings about caldav and carddav. For some reason I was never able to setup caddy2 as a reverse proxy using a Caddyfile. I am able to do that with the JSON config that I have. I would like to know how to add the correct entries in the caddy2 reverse proxy json config file.
none
I found that using the regular Caddyfile, we can do
but how would we do this in the json config
