caddy version
v2.6.4
how install caddy?
Download using the official apt repository
apt install caddy
error message
❯ caddy add-package github.com/awoodbeck/caddy-toml-adapter
2023/03/29 14:30:22.279 INFO this executable will be replaced {"path": "/usr/bin/caddy"}
2023/03/29 14:30:22.279 INFO requesting build {"os": "linux", "arch": "amd64", "packages": ["github.com/awoodbeck/caddy-toml-adapter", "github.com/caddy-dns/cloudflare"]}
Error: download failed: download failed: HTTP 400: github.com/awoodbeck/caddy-toml-adapter is not a registered Caddy module package path (id=4d9174c4-40b4-4f80-bb1b-cfd89c813899)
Because I use apt to install, not to compile and install.
So I add the module using caddy add-package.
But this module is not registered Caddy. How can I add this module?
