Solved:
Ok, I figure it out. The port was excluded from this service I had “World Wide Web Publishing Service”. I don’t know where that came from, but I disabled the serviced and now caddy is working perfectly again!
2.4.5
I just want to run it to run a static file and have it redirect my dynamic dns to https.
Windows 10
caddy.exe start
NONE
Caddyfile: (first part of address changed for privacy)
mydns.tplinkdns.com
root * C:/Users/a1/www/root/
When I try to start caddy with my Caddyfile there, it doesn’t even use it. I did have it working at first and it was fine, so I don’t know what I did. I cant even use a basic caddyfile from the tutorial anymore either.
C:\Users\a1>caddy.exe start
2021/10/11 02:11:26.067 INFO using adjacent Caddyfile
2021/10/11 02:11:26.077 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["[::1]:2019", "127.0.0.1:2019", "localhost:2019"]}
2021/10/11 02:11:26.077 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00037eee0"}
2021/10/11 02:11:26.077 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2021/10/11 02:11:26.078 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2021/10/11 02:11:26.081 INFO tls.cache.maintenance stopped background certificate maintenance {"cache": "0xc00037eee0"}
run: loading initial config: loading new config: http app module: start: tcp: listening on :80: listen tcp :80: bind: An attempt was made to access a socket in a way forbidden by its access permissions.
start: caddy process exited with error: exit status 1
Since I did have it working before, I uninstalled, searched my computer for any folder referencing caddy or caddyfile and deleted and then I tried to start over, even going back to following the tutorial but it wont work. As you an see the output says its using the adjacent Caddyfile, but in fact my Caddyfile has nothing about port 2019 and I don’t know what its talking about the socket.
None
