1. Output of caddy version
AlmaLinux 8.6
systemctl start caddy
[root@sub ~]# systemctl cat caddy
# /run/systemd/generator.late/caddy.service
# Automatically generated by systemd-sysv-generator
Documentation=man:systemd-sysv-generator(8)
SourcePath=/etc/rc.d/init.d/caddy
Description=LSB: It can help you improve network speed
Before=multi-user.target
Before=graphical.target
After=network-online.target
Wants=network-online.target
Type=forking
Restart=no
TimeoutSec=5min
IgnoreSIGPIPE=no
KillMode=process
GuessMainPID=no
RemainAfterExit=yes
SuccessExitStatus=5 6
ExecStart=/etc/rc.d/init.d/caddy start
ExecStop=/etc/rc.d/init.d/caddy stop
[root@sub~]# systemctl status caddy
● caddy.service - LSB: It can help you improve network speed
Loaded: loaded (/etc/rc.d/init.d/caddy; generated)
Active: active (exited) since Tue 2022-08-02 22:25:31 EDT; 8h ago
Docs: man:systemd-sysv-generator(8)
Process: 1379 ExecStart=/etc/rc.d/init.d/caddy start (code=exited, status=0/SUCCESS)
Tasks: 0 (limit: 4945)
Memory: 0B
Aug 02 22:25:30 sub.example.com systemd[1]: Starting LSB: It can help you improve network speed...
Aug 02 22:25:31 sub.example.com caddy[1379]: Starting caddy success
Aug 02 22:25:31 sub.example.com systemd[1]: Started LSB: It can help you improve network speed.
sub.example.com:443 {
Strict-Transport-Security "max-age=31536000; includeSubDomains"
-Server
output file /var/log/caddy-access.log
format json
tls /root/.acme.sh/sub.example.com_ecc/fullchain.cer /root/.acme.sh/sub.example.com_ecc/sub.example.com.key {
protocols tls1.3
reverse_proxy /dueIU localhost:11563
reverse_proxy 127.0.0.1:8563 {
Everything works just fine except I cannot start Caddy after I manually stop it if I use systemctl start caddy
Restarting Caddy also fails with systemctl restart caddy
I have to reboot the server to get Caddy to run again.
Aug 02 22:07:23 cloud.servutech.com caddy[1863]: Starting caddy failed
Aug 02 22:07:23 cloud.servutech.com systemd[1]: caddy.service: Control process exited, code=exited status=1
Aug 02 22:07:23 cloud.servutech.com systemd[1]: caddy.service: Failed with result 'exit-code'.
Aug 02 22:07:23 cloud.servutech.com systemd[1]: Failed to start LSB: It can help you improve network speed.
Aug 02 22:07:49 cloud.servutech.com systemd[1]: caddy.service: Found left-over process 1872 (caddy) in control group while starting unit. Ignoring.
Aug 02 22:07:49 cloud.servutech.com systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Aug 02 22:07:49 cloud.servutech.com systemd[1]: Starting LSB: It can help you improve network speed...
Aug 02 22:07:49 cloud.servutech.com caddy[1895]: /etc/rc.d/init.d/caddy: line 33: [: 1872: binary operator expected
Aug 02 22:07:49 cloud.servutech.com caddy[1895]: Starting caddy failed
Aug 02 22:07:49 cloud.servutech.com systemd[1]: caddy.service: Control process exited, code=exited status=1
Aug 02 22:07:49 cloud.servutech.com systemd[1]: caddy.service: Failed with result 'exit-code'.
Aug 02 22:07:49 cloud.servutech.com systemd[1]: Failed to start LSB: It can help you improve network speed.
