I’ve followed the systemd service guide and I’m using caddy.service
from that link.
When starting via systemctl, caddy does not start and exits.
When I log into www-data
via sudo su -l www-data -s /bin/bash
and then run
caddy -log stdout -agree=true -email carsten@chagemann.de -conf=/etc/caddy/Caddyfile -root=/var/tmp
caddy starts just fine and starts serving.
Any clue why this is happening? Debian 9, Caddy 0.10.10 with some plugins.
shell@debian-2gb-nbg1-dc3-3:/etc/systemd/system$ sudo systemctl status caddy.service
● caddy.service - Caddy HTTP/2 web server
Active: failed (Result: exit-code) since Sun 2018-01-28 21:24:28 CET; 4s ago
Docs: https://caddyserver.com/docs
Process: 26946 ExecStart=/usr/local/bin/caddy -log stdout -agree=true -email carsten@chagemann.de -conf=/etc/caddy/Caddyfile -root=/var/tmp (code=exited, status=1/FAILURE)
Main PID: 26946 (code=exited, status=1/FAILURE)
Jan 28 21:24:26 debian-2gb-nbg1-dc3-3 systemd[1]: Started Caddy HTTP/2 web server.
Jan 28 21:24:26 debian-2gb-nbg1-dc3-3 caddy[26946]: Activating privacy features...2018/01/28 21:24:26 [INFO] acme: Registering account for carsten@chagemann.de
Jan 28 21:24:27 debian-2gb-nbg1-dc3-3 caddy[26946]: 2018/01/28 21:24:27 [INFO][chagemann.de] acme: Obtaining bundled SAN certificate
Jan 28 21:24:28 debian-2gb-nbg1-dc3-3 caddy[26946]: 2018/01/28 21:24:28 [INFO][chagemann.de] AuthURL: https://acme-v01.api.letsencrypt.org/acme/authz/e0StpVHGjKdCZUoc-NeorvZx1SQXbSPfS42Rn
Jan 28 21:24:28 debian-2gb-nbg1-dc3-3 caddy[26946]: 2018/01/28 21:24:28 [INFO][chagemann.de] acme: Trying to solve HTTP-01
Jan 28 21:24:28 debian-2gb-nbg1-dc3-3 caddy[26946]: 2018/01/28 21:24:28 [chagemann.de] failed to get certificate: [chagemann.de] error presenting token: Could not start HTTP server for ch
Jan 28 21:24:28 debian-2gb-nbg1-dc3-3 systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Jan 28 21:24:28 debian-2gb-nbg1-dc3-3 systemd[1]: caddy.service: Unit entered failed state.
Jan 28 21:24:28 debian-2gb-nbg1-dc3-3 systemd[1]: caddy.service: Failed with result 'exit-code'.
Entire caddy.service file:
After=network-online.target
Restart=on-abnormal
User=www-data
Group=www-data
; Always set "-root" to something safe in case it gets forgotten in the Caddyfile.
ExecReload=/bin/kill -USR1 $MAINPID
; Use graceful shutdown with a reasonable timeout
KillMode=mixed
KillSignal=SIGQUIT
; Unmodified caddy is not expected to use more than that.
; Use a minimal /dev
PrivateDevices=true
ProtectHome=true
; … except /etc/ssl/caddy, because we want Letsencrypt-certificates there.
; This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
ReadWriteDirectories=/etc/ssl/caddy
; They further retrict privileges that can be gained by caddy. Uncomment if you like.
;CapabilityBoundingSet=CAP_NET_BIND_SERVICE
;AmbientCapabilities=CAP_NET_BIND_SERVICE
;NoNewPrivileges=true
