2.4.6
CentOS 7
systemctl start caddy, or caddy run
# caddy.service
# for your installation.
Type=notify
bb-lg.comcast.net:443 {
tls /etc/caddy/bb-lg.comcast.net.pem /etc/caddy/bb-lg.comcast.net.key
file_server {
root /etc/hyperglass/static/ui
file_server /custom/* {
root /etc/hyperglass/static/custom/
file_server /images/* {
root /etc/hyperglass/static/images/
reverse_proxy localhost:8001
My tls certs expired, so I had to update them. I copied the new pem and key file to /etc/caddy using the same names as what was already in use, then I restarted caddy but it fails to restart.
$ caddy start
2022/04/27 17:17:18.726 INFO using adjacent Caddyfile
2022/04/27 17:17:18.728 WARN input is not formatted with ‘caddy fmt’ {“adapter”: “caddyfile”, “file”: “Caddyfile”, “line”: 2}
2022/04/27 17:17:18.729 INFO admin admin endpoint started {“address”: “tcp/localhost:2019”, “enforce_origin”: false, “origins”: [“localhost:2019”, “[::1]:2019”, “127.0.0.1:2019”]}
2022/04/27 17:17:18.730 INFO tls.cache.maintenance started background certificate maintenance {“cache”: “0xc0000e76c0”}
2022/04/27 17:17:18.730 INFO tls.cache.maintenance stopped background certificate maintenance {“cache”: “0xc0000e76c0”}
run: loading initial config: loading new config: loading http app module: provision http: getting tls app: loading tls app module: provision tls: loading certificates: tls: failed to find “CERTIFICATE” PEM block in certificate input after skipping PEM blocks of the following types: [DH PARAMETERS]
start: caddy process exited with error: exit status 1
I’m not sure what to try since it was working previously with the old certificate. I changed nothing except the certificate pem and key file. I did not alter Caddyfile and it is using the same filenames.
