Arch Linux on a Linode VPS
systemd 247 (247.2-1-arch)
+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid
# caddy.service
# for your installation.
Description=Caddy webserver
StartLimitIntervalSec=14400
StartLimitBurst=10
Environment=XDG_DATA_HOME=/var/lib
Environment=XDG_CONFIG_HOME=/var/lib/caddy/.config
; caddy command assumes the caddyfile adapter if filename starts with Caddyfile
# Do not allow the process to be restarted in a tight loop. If the
# process fails to start, something critical needs to be fixed.
Restart=on-abnormal
# Use graceful shutdown with a reasonable timeout
KillMode=mixed
KillSignal=SIGQUIT
; Raise limit for file descriptors; see `man systemd.exec` for more limit settings.
# Hardening options
PrivateDevices=true
ProtectHome=true
ProtectSystem=strict
ReadWritePaths=/var/lib/caddy /var/log/caddy
NoNewPrivileges=true
ProtectKernelTunables=true
ProtectKernelModules=true
ProtectControlGroups=true
LockPersonality=true
# global options block: https://caddyserver.com/docs/caddyfile/options
servers {
protocol {
experimental_http3
email {{ admin_email }}
# reusable snippets: https://caddyserver.com/docs/caddyfile/concepts#snippets
(boilerplate) {
encode gzip zstd
# redirect no-www to www
(redir-to-www) {
{args.0} {
redir https://www.{args.0}{uri}
# start site blocks
# test page
test.maximumethics.dev {
root * /srv/maximumethics.dev/test/public/
import boilerplate
# https://caddyserver.com/docs/caddyfile/directives/templates
# can't use default double curly braces b/c Ansible uses them
templates {
between (( ))
# handcoded Rhode Island site
# Hugo sites
www.maximumethics.dev {
root * /srv/maximumethics.dev/www/public
encode gzip zstd
file_server browse
import redir-to-www maximumethics.dev
I’m trying to reload Caddy to take in the “new config”, but the only thing I changed in my Caddyfile was fixing the “experimental_http3” global option which was deprecated, and removing that entirely doesn’t change anything.
Here’s a relevant section of my systemd journal journalctl -u caddy
Jan 12 18:40:20 america systemd[1]: Reloading Caddy webserver.
Jan 12 18:40:20 america caddy[1163664]: {"level":"info","ts":1610494820.195494,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Jan 12 18:40:20 america caddy[201731]: {"level":"info","ts":1610494820.1994202,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_addr":"127.0.0.1:39972","headers":{"Accept-Encoding":["gzip"],"Content-Length":["1222"],"Content-Type":["application/json"],"Origin":["localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Jan 12 18:40:20 america caddy[201731]: {"level":"info","ts":1610494820.2002597,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Jan 12 18:40:20 america caddy[201731]: {"level":"error","ts":1610494820.200391,"logger":"admin.api","msg":"request error","error":"loading config: loading new config: loading tls app module: decoding module config: tls: json: unknown field \"issuers\"","status_code":400}
Jan 12 18:40:20 america caddy[1163664]: reload: sending configuration to instance: caddy responded with error: HTTP 400: {"error":"loading config: loading new config: loading tls app module: decoding module config: tls: json: unknown field \"issuers\""}
Jan 12 18:40:20 america systemd[1]: caddy.service: Control process exited, code=exited, status=1/FAILURE
Jan 12 18:40:20 america systemd[1]: Reload failed for Caddy webserver.
Jan 12 18:40:20 america caddy[201731]: {"level":"info","ts":1610494820.7006083,"logger":"admin","msg":"stopped previous server"}
I have no idea where to start, I searched my Caddyfile and other config files for the field “issuers” and had no joy. What is that field “issuers” and where is it coming from?
