new log i changed the caddyfile because his docker stopped and that can be fixed another day
PS C:\Tools\Caddy> ./caddy run --config Caddyfile
2023/01/22 06:13:42.156 INFO using provided configuration {"config_file": "Caddyfile", "config_adapter": ""}
2023/01/22 06:13:42.181 WARN Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies {"adapter": "caddyfile", "file": "Caddyfile", "line": 2}
2023/01/22 06:13:42.188 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//[::1]:2019", "//127.0.0.1:2019", "//localhost:2019"]}
2023/01/22 06:13:42.189 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000624f50"}
2023/01/22 06:13:42.189 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2023/01/22 06:13:42.189 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2023/01/22 06:13:42.192 INFO tls cleaning storage unit {"description": "FileStorage:C:\\Users\\jessi\\AppData\\Roaming\\Caddy"}
2023/01/22 06:13:42.193 INFO http enabling HTTP/3 listener {"addr": ":443"}
2023/01/22 06:13:42.194 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2023/01/22 06:13:42.194 INFO http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2023/01/22 06:13:42.194 INFO http enabling automatic TLS certificate management {"domains": ["navarre-home-qbit.duckdns.org", "navarre-home-tv.duckdns.org", "navarre-home-movies.duckdns.org", "navarre-home-music.duckdns.org"]}
2023/01/22 06:13:42.236 INFO autosaved config (load with --resume flag) {"file": "C:\\Users\\jessi\\AppData\\Roaming\\Caddy\\autosave.json"}
2023/01/22 06:13:42.239 INFO serving initial configuration
2023/01/22 06:13:42.245 INFO tls.obtain acquiring lock {"identifier": "navarre-home-movies.duckdns.org"}
2023/01/22 06:13:42.246 INFO tls.obtain acquiring lock {"identifier": "navarre-home-tv.duckdns.org"}
2023/01/22 06:13:42.286 INFO tls.obtain acquiring lock {"identifier": "navarre-home-music.duckdns.org"}
2023/01/22 06:13:42.294 INFO tls finished cleaning storage units
2023/01/22 06:13:42.374 INFO tls.obtain lock acquired {"identifier": "navarre-home-movies.duckdns.org"}
2023/01/22 06:13:42.376 INFO tls.obtain lock acquired {"identifier": "navarre-home-tv.duckdns.org"}
2023/01/22 06:13:42.383 INFO tls.obtain obtaining certificate {"identifier": "navarre-home-tv.duckdns.org"}
2023/01/22 06:13:42.386 INFO http waiting on internal rate limiter {"identifiers": ["navarre-home-tv.duckdns.org"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2023/01/22 06:13:42.386 INFO http done waiting on internal rate limiter {"identifiers": ["navarre-home-tv.duckdns.org"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2023/01/22 06:13:42.396 INFO tls.obtain lock acquired {"identifier": "navarre-home-music.duckdns.org"}
2023/01/22 06:13:42.398 INFO tls.obtain obtaining certificate {"identifier": "navarre-home-music.duckdns.org"}
2023/01/22 06:13:42.397 INFO tls.obtain obtaining certificate {"identifier": "navarre-home-movies.duckdns.org"}
2023/01/22 06:13:42.403 INFO http waiting on internal rate limiter {"identifiers": ["navarre-home-music.duckdns.org"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2023/01/22 06:13:42.406 INFO http done waiting on internal rate limiter {"identifiers": ["navarre-home-music.duckdns.org"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2023/01/22 06:13:42.406 INFO http waiting on internal rate limiter {"identifiers": ["navarre-home-movies.duckdns.org"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2023/01/22 06:13:42.407 INFO http done waiting on internal rate limiter {"identifiers": ["navarre-home-movies.duckdns.org"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2023/01/22 06:13:42.803 INFO http.acme_client trying to solve challenge {"identifier": "navarre-home-tv.duckdns.org", "challenge_type": "dns-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2023/01/22 06:13:42.812 INFO http.acme_client trying to solve challenge {"identifier": "navarre-home-movies.duckdns.org", "challenge_type": "dns-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2023/01/22 06:13:42.814 INFO http.acme_client trying to solve challenge {"identifier": "navarre-home-music.duckdns.org", "challenge_type": "dns-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2023/01/22 06:13:43.737 INFO http.acme_client authorization finalized {"identifier": "navarre-home-movies.duckdns.org", "authz_status": "valid"}
2023/01/22 06:13:43.737 INFO http.acme_client validations succeeded; finalizing order {"order": "https://acme-v02.api.letsencrypt.org/acme/order/928021197/160287223737"}
2023/01/22 06:13:44.603 INFO http.acme_client successfully downloaded available certificate chains {"count": 2, "first_url": "https://acme-v02.api.letsencrypt.org/acme/cert/0392dcc462977f0d7e44c72a714d40682e25"}
2023/01/22 06:13:44.605 INFO tls.obtain certificate obtained successfully {"identifier": "navarre-home-movies.duckdns.org"}
2023/01/22 06:13:44.610 INFO tls.obtain releasing lock {"identifier": "navarre-home-movies.duckdns.org"}
2023/01/22 06:13:46.240 INFO http.acme_client authorization finalized {"identifier": "navarre-home-tv.duckdns.org", "authz_status": "valid"}
2023/01/22 06:13:46.240 INFO http.acme_client validations succeeded; finalizing order {"order": "https://acme-v02.api.letsencrypt.org/acme/order/928021197/160287223757"}
2023/01/22 06:13:46.744 INFO http.acme_client authorization finalized {"identifier": "navarre-home-music.duckdns.org", "authz_status": "valid"}
2023/01/22 06:13:46.744 INFO http.acme_client validations succeeded; finalizing order {"order": "https://acme-v02.api.letsencrypt.org/acme/order/928021197/160287223727"}
2023/01/22 06:13:47.141 INFO http.acme_client successfully downloaded available certificate chains {"count": 2, "first_url": "https://acme-v02.api.letsencrypt.org/acme/cert/034043004e99a0d110214f96ae79101f9903"}
2023/01/22 06:13:47.164 INFO tls.obtain certificate obtained successfully {"identifier": "navarre-home-tv.duckdns.org"}
2023/01/22 06:13:47.165 INFO tls.obtain releasing lock {"identifier": "navarre-home-tv.duckdns.org"}
2023/01/22 06:13:47.178 INFO http.acme_client successfully downloaded available certificate chains {"count": 2, "first_url": "https://acme-v02.api.letsencrypt.org/acme/cert/03ae6f4910fba6cf400d575388d9a2dc8af4"}
2023/01/22 06:13:47.187 INFO tls.obtain certificate obtained successfully {"identifier": "navarre-home-music.duckdns.org"}
2023/01/22 06:13:47.191 INFO tls.obtain releasing lock {"identifier": "navarre-home-music.duckdns.org"}
2023/01/22 06:14:05.959 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "15.204.173.67", "remote_port": "47260", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/", "headers": {"Connection": ["keep-alive"], "User-Agent": ["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"], "Accept-Encoding": ["gzip, deflate"], "Accept": ["*/*"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "http/1.1", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 3.0289342, "status": 502, "err_id": "cuywy8yry", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:13.644 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "195.211.77.140", "remote_port": "58390", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/", "headers": {"Accept-Language": ["ru-RU,ru;q=0.8,en-US;q=0.5,en;q=0.3"], "User-Agent": ["Mozilla/5.0 (Windows NT 6.1; Windows NT 5.1; en-US) AppleWebKit/525.13 (KHTML, like Gecko) Chrome/stable Safari/525.13"], "Accept-Encoding": ["*"], "Accept": ["*/*"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 3.0117316, "status": 502, "err_id": "1q7fykjxv", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:14.215 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "51.75.169.50", "remote_port": "42392", "proto": "HTTP/2.0", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/", "headers": {"Accept-Encoding": ["gzip"], "User-Agent": ["Go-http-client/2.0"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 3.0051798, "status": 502, "err_id": "ejc271cp1", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:19.138 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "63.135.161.175", "remote_port": "11611", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/", "headers": {"Accept": ["*/*"], "Accept-Encoding": ["gzip, deflate"], "User-Agent": ["Python/3.8 aiohttp/3.8.3"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 3.0057346, "status": 502, "err_id": "bd55zaj6j", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:20.982 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "139.144.69.48", "remote_port": "36850", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/", "headers": {}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 3.0028543, "status": 502, "err_id": "s3prizaqm", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:21.920 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "68.183.18.118", "remote_port": "54728", "proto": "HTTP/2.0", "method": "HEAD", "host": "navarre-home-music.duckdns.org", "uri": "/", "headers": {"Referer": ["http://navarre-home-music.duckdns.org"], "User-Agent": ["Mozilla/5.0 (compatible; Domains Project/1.3.7; +https://domainsproject.org)"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 3.0143077, "status": 502, "err_id": "0n67fe0n3", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:24.229 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "205.169.39.63", "remote_port": "53047", "proto": "HTTP/2.0", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/", "headers": {"Upgrade-Insecure-Requests": ["1"], "Accept-Language": ["en-US"], "Cache-Control": ["no-cache"], "User-Agent": ["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) HeadlessChrome/104.0.5112.101 Safari/537.36"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"], "Sec-Fetch-Site": ["none"], "Sec-Fetch-Mode": ["navigate"], "Sec-Fetch-User": ["?1"], "Sec-Fetch-Dest": ["document"], "Accept-Encoding": ["gzip, deflate, br"], "Pragma": ["no-cache"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 3.0139536, "status": 502, "err_id": "vrgr8k8vg", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:29.629 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "63.135.161.175", "remote_port": "11611", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/", "headers": {"Accept-Encoding": ["gzip, deflate"], "User-Agent": ["Python/3.8 aiohttp/3.8.3"], "Accept": ["*/*"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 3.0156684, "status": 502, "err_id": "8q6ms3yrf", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:45.949 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "139.144.69.48", "remote_port": "54104", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/.vscode/sftp.json", "headers": {"User-Agent": ["Go-http-client/1.1"], "Accept-Encoding": ["gzip"], "Connection": ["close"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 14.8620792, "status": 502, "err_id": "gdfmaxz18", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:46.038 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "139.144.69.48", "remote_port": "54106", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/debug/default/view?panel=config", "headers": {"Accept-Encoding": ["gzip"], "Connection": ["close"], "User-Agent": ["Go-http-client/1.1"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 14.951113, "status": 502, "err_id": "edxasjnvk", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:46.038 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "139.144.69.48", "remote_port": "54126", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/.DS_Store", "headers": {"User-Agent": ["Go-http-client/1.1"], "Accept-Encoding": ["gzip"], "Connection": ["close"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 14.9137965, "status": 502, "err_id": "cnvj9zg5b", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:46.038 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "139.144.69.48", "remote_port": "54144", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/", "headers": {"User-Agent": ["Mozilla/5.0 (Linux; Android 6.0; HTC One M9 Build/MRA799449) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.1279.98 Mobile Safari/537.3"], "Connection": ["close"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 14.9299445, "status": 502, "err_id": "ku7j0qz5s", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:46.038 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "139.144.69.48", "remote_port": "54136", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/.env", "headers": {"Accept-Encoding": ["gzip"], "Connection": ["close"], "User-Agent": ["Go-http-client/1.1"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 14.934967, "status": 502, "err_id": "qbndw1tga", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:46.038 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "139.144.69.48", "remote_port": "54120", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/server-status", "headers": {"User-Agent": ["Go-http-client/1.1"], "Accept-Encoding": ["gzip"], "Connection": ["close"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 14.9500538, "status": 502, "err_id": "e967m84rg", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:46.039 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "139.144.69.48", "remote_port": "54154", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/s/7343e25333e22373e26373/_/;/META-INF/maven/com.atlassian.jira/jira-webapp-dist/pom.properties", "headers": {"User-Agent": ["Go-http-client/1.1"], "Accept-Encoding": ["gzip"], "Connection": ["close"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 14.9309443, "status": 502, "err_id": "6imvt9gne", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:46.118 ERROR http.log.error dial tcp 192.168.1.9:6969: i/o timeout {"request": {"remote_ip": "139.144.69.48", "remote_port": "54108", "proto": "HTTP/1.1", "method": "GET", "host": "navarre-home-music.duckdns.org", "uri": "/ecp/Current/exporttool/microsoft.exchange.ediscovery.exporttool.application", "headers": {"Accept-Encoding": ["gzip"], "Connection": ["close"], "User-Agent": ["Go-http-client/1.1"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "navarre-home-music.duckdns.org"}}, "duration": 15.0312193, "status": 502, "err_id": "29zp1r0kx", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2023/01/22 06:14:46.420 INFO shutting down {"signal": "SIGINT"}
2023/01/22 06:14:47.213 WARN exiting; byeee!! 👋 {"signal": "SIGINT"}
2023/01/22 06:14:48.667 ERROR http.log setting HTTP/3 Alt-Svc header {"error": "no port can be announced, specify it explicitly using Server.Port or Server.Addr"}
2023/01/22 06:14:48.787 ERROR http.log setting HTTP/3 Alt-Svc header {"error": "no port can be announced, specify it explicitly using Server.Port or Server.Addr"}
2023/01/22 06:14:49.042 ERROR http.log setting HTTP/3 Alt-Svc header {"error": "no port can be announced, specify it explicitly using Server.Port or Server.Addr"}
2023/01/22 06:14:53.886 INFO tls.cache.maintenance stopped background certificate maintenance {"cache": "0xc000624f50"}
2023/01/22 06:14:54.002 INFO admin stopped previous server {"address": "localhost:2019"}
2023/01/22 06:14:54.002 INFO shutdown complete {"signal": "SIGINT", "exit_code": 0}
Caddyfile
navarre-home-tv.duckdns.org {
reverse_proxy 192.168.1.6:8989
issuer acme {
dns duckdns access-token
propagation_timeout -1
issuer zerossl {
navarre-home-qbit.duckdns.org {
reverse_proxy 192.168.1.6:8084
issuer acme {
issuer zerossl {
navarre-home-music.duckdns.org {
reverse_proxy 192.168.1.9:6969
issuer acme {
issuer zerossl {
navarre-home-movies.duckdns.org {
reverse_proxy 192.168.1.11:7878
issuer acme {
issuer zerossl {
BTW we are remoting into his pc in another state. He travels for work and remotes in using google chrome remote. I dont think this will affect the pc internal ip and external ip of his home based wired systems.
