Ubuntu 18.04.4
Installed via apt.
Caddy is running as a service so I am running:
caddy reload
In the directory where my config is.
email myemail@provider.com
http://site.com, http://localhost {
respond "I am server"
There is no response when attempting to access externally. I.e. going to site.com just hangs.
No errors. Running caddy start
2020/05/09 12:49:07.081 INFO using adjacent Caddyfile
2020/05/09 12:49:07.081 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2020/05/09 12:49:07.081 INFO tls cleaned up storage units
2020/05/09 13:49:07 [INFO][cache:0xc00062b770] Started certificate maintenance routine
2020/05/09 12:49:07.081 INFO autosaved config {"file": "/home/rhys/.config/caddy/autosave.json"}
2020/05/09 12:49:07.081 INFO serving initial configuration
Successfully started Caddy (pid=32688) - Caddy is running in the background
And running caddy reload
2020/05/09 12:49:11.765 INFO using adjacent Caddyfile
2020/05/09 12:49:11.766 INFO admin.api received request {"method": "POST", "host": "localhost:2019", "uri": "/load", "remote_addr": "127.0.0.1:41018", "headers": {"Accept-Encoding":["gzip"],"Content-Length":["164"],"Content-Type":["application/json"],"Origin":["localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
2020/05/09 12:49:11.766 INFO admin.api config is unchanged
2020/05/09 12:49:11.766 INFO admin.api load complete
- Responds correctly on the machine with
curl localhost
- Pinging domain name works, sshing to domain name works, and I have a some nginx docker containers that I can boot up that do respond on port 80/443 of the domain name, so I’m sure the DNS records are configured correctly.
- Ran
sudo setcap CAP_NET_BIND_SERVICE=+eip /usr/bin/caddy
so it could run on 80/443 without root.
