coolaj86
(AJ ONeal)
May 26, 2020, 9:58pm
#1
v2.0.0
Ubuntu 18.04
I’m looking at the v2 log docs and I don’t understand how to choose specific things to log or not log.
For example, I’d like to print something like this:
<method> <response code> <path> <referer>
I don’t want to log all cookies and all headers, etc, but rather just a few things.
Not even sure what to try.
matt
(Matt Holt)
May 26, 2020, 10:15pm
#2
Hey AJ,
You can read about logging here: How Logging Works — Caddy Documentation
Basically: the logs are structured, so just ignore the fields or lines you don’t want. That is the easiest, and highest-performance way.
coolaj86
(AJ ONeal)
June 22, 2020, 6:35pm
#3
I’m not quite sure I understand.
Ultimately, log processing is out of the scope of Caddy core.
there’s always the possibility for a Caddy app module that consumes logs. (It just doesn’t exist yet
Are you saying that the correct and expected way is for me to write a Caddy logger plugin in Go that follows logfmt? That there is no configuration?
coolaj86
(AJ ONeal)
June 22, 2020, 6:44pm
#4
I see there’s some documentation on filters here:
But I’m not clear on how that relates to a Caddyfile or the API.
I realize that with the switch to v2 there are a lot of changes to prior conventions and it will be a while before all of the modules are updated with specific examples. It looks like the “meta” examples are pretty much all there, but it’s still a bit challenging to figure out how they apply to a use case.
Is there a repository of example Caddyfiles or curl commands that cover how to use the various modules in a more concrete way?
Since you first asked this, a new plugin was written to help cover this usecase:
Note that it’s more expensive to run than the core capabilities. Probably won’t be an issue unless you get to truly huge scale.
system
(system)
closed
June 25, 2020, 9:58pm
#6
