emby.xxx.me {
push
tls xxx {
dns cloudflare xxx
output file /config/log/caddy.e.log {
roll true # Rotate logs, enabled by default
roll_size_mb 5 # Set max size 5 MB
roll_gzip true # Whether to compress rolled files
roll_local_time true # Use localhost time
roll_keep 2 # Keep at most 2 log files
roll_keep_days 7 # Keep log files for 7 days
reverse_proxy 127.0.0.1:8096 {
header_up Host {host}
header_up X-Forwarded-For {remote_host}
I need add from nginx.
proxy_set_header Range $http_range;
proxy_set_header If-Range $http_if_range;
