caddy v2.2.0-rc.1 h1:ULGBB9efRs8yG27IBOMLljhCa4iM1IluFTDxjm+Y8vE=
emby.xxx.me {
tls xxx@hotmail.com {
dns cloudflare xxx
output file /config/log/caddy.e.log {
roll true # Rotate logs, enabled by default
roll_size_mb 5 # Set max size 5 MB
roll_gzip true # Whether to compress rolled files
roll_local_time true # Use localhost time
roll_keep 2 # Keep at most 2 log files
roll_keep_days 7 # Keep log files for 7 days
reverse_proxy * 127.0.0.1:8096 {
header_up Host {host}
header_up X-Forwarded-Proto {proto}
2020/09/17 05:53:09.997 INFO using provided configuration {"config_file": "/mnt/config/caddy/Caddyfile", "config_adapter": ""}
2020/09/17 05:53:09.998 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["127.0.0.1:2019", "localhost:2019", "[::1]:2019"]}
2020/09/17 05:53:09.999 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000494230"}
2020/09/17 05:53:09.999 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2020/09/17 05:53:09.999 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2020/09/17 05:53:09.999 INFO http enabling automatic TLS certificate management {"domains": ["emby.xxx.me"]}
2020/09/17 05:53:10.000 INFO tls cleaned up storage units
2020/09/17 05:53:10.009 INFO autosaved config {"file": "/root/.config/caddy/autosave.json"}
2020/09/17 05:53:10.009 INFO serving initial configuration
2020/09/17 05:56:44.562 ERROR http.handlers.reverse_proxy aborting with incomplete response {"error": "write tcp 10.148.0.20:443->172.69.135.243:47706: write: connection reset by peer"}
Help me!!! ERROR http.handlers.reverse_proxy
