I have two servers running in my home. Since I can only forward port 443 to one of the machines, I want it to reverse-proxy to the other server
Currently, port 443 is forwarded to yeda-server
Within that server’s Caddyfile, any hostname under a deanayalon.com
is reverse-proxied to dean-linux
(I’d have used a wildcard domain, but I can’t do the DNS-01 challenge)
I believe that the configuration is generally correct for yeda-server. If I spin up a container on dean-linux:443, the hostnames under deanayalon.com get there and I can use the service
But if I try to create a Caddy container on dean-linux, it tries issuing certificates, which is not possible, seeing as :80 arrives at yeda-server, which itself issues certificate requests.
Is there a way to have those two Caddy servers communicate so that the inner one uses the external one’s certificates, and does not try to issue them itself?
"level": "error",
"ts": 1726527929.4295866,
"logger": "tls.issuance.acme.acme_client",
"msg": "validating authorization",
"identifier": "filemaker.deanayalon.com",
"problem": {
"type": "urn:ietf:params:acme:error:tls",
"title": "",
"detail": "62.0.120.246: remote error: tls: internal error",
"instance": "",
"subproblems": []
"order": "https://acme-v02.api.letsencrypt.org/acme/order/1950502556/305757599826",
"attempt": 1,
"max_attempts": 3
"level": "error",
"ts": 1726527930.6718748,
"logger": "tls.obtain",
"msg": "could not get certificate from issuer",
"issuer": "acme-v02.api.letsencrypt.org-directory",
"error": "HTTP 429 urn:ietf:params:acme:error:rateLimited - Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/failed-validation-limit/"
"level": "error",
"ts": 1726527932.7435188,
"identifier": "onedev.deanayalon.com",
"problem": {
"type": "urn:ietf:params:acme:error:unauthorized",
"title": "",
"detail": "62.0.120.246: Invalid response from https://onedev.deanayalon.com/.well-known/acme-challenge/tLat3xbKaZ3QIe6wAW6YtRwwa3tGUPg6xYsUQ9ile8g: 502",
"instance": "",
"subproblems": []
"order": "https://acme-v02.api.letsencrypt.org/acme/order/1950502556/305757609216",
"attempt": 2,
"max_attempts": 3
"level": "error",
"ts": 1726527932.743571,
"error": "HTTP 403 urn:ietf:params:acme:error:unauthorized - 62.0.120.246: Invalid response from https://onedev.deanayalon.com/.well-known/acme-challenge/tLat3xbKaZ3QIe6wAW6YtRwwa3tGUPg6xYsUQ9ile8g: 502"
Using the caddy image for Docker
Yeda-Server:
MacOS Sonoma 14.6.1 (M1 Max chip)
Docker Desktop 4.33.0 (Engine 27.1.1)
Dean-Linux:
Manjaro Linux 24.0.8 Wynsdey (AMD64)
Docker Engine 27.1.2
b. Command
docker compose up -d
compose.yml (Identical in both servers)
image: caddy
hostname: caddy
- 443:443
- 443:443/udp
- ./site:/srv:ro
- ./log:/var/log
- data:/data/caddy
- config:/config/caddy
env_file:
- .env
data:
config:
Yeda-server’s Caddyfile:
email {$EMAIL}
(tls-insecure) {
reverse_proxy {args[0]}:443 {
tls
tls_insecure_skip_verify
(log) {
output file /var/log/{args[0]}.log
format json
filemaker.yeda-water.com:443 {
import log filemaker
import tls-insecure fms
(dean) {
{args[0]}.deanayalon.com:443 {
import log dean/{args[0]}
import tls-insecure {$DEAN_IP}
import dean filemaker
import dean onedev
dean-linux’s Caddyfile:
email {$EMAIL}
(tls-insecure) {
reverse_proxy {args[0]} {
tls
(log) {
format json
filemaker.deanayalon.com:443 {
import tls-insecure fms:443
onedev.deanayalon.com:443 {
import log onedev
reverse_proxy onedev:6610 {
tls
Unfortunately, though I remember reading mention of multiple Caddy server management, I could not find any documentation or forum threads about configuring that, my apologies if I missed something
