Caddy Struggles to STOP
1. Caddy version:
Using Caddy official documentation
Ubuntu 22.04.1 LTS (GNU/Linux 5.15.0-58-generic x86_64)
caddy stop
    "logging": {
        "logs": {
            "default": {
                "exclude": [
                    "http.log.access.logFiltered",
                    "http.handlers.mercure"
            "logFiltered": {
                "level": "ERROR",
                "include": [
    "apps": {
        "http": {
            "servers": {
                "srv0": {
                    "listen": [
                        ":443"
                    "routes": [
                            "match": [
                                    "host": [
                                        "test.domainname.com"
                            "handle": [
                                    "handler": "subroute",
                                    "routes": [
                                            "handle": [
                                                    "routes": [
                                                            "handle": [
        "cors_origins": [
        "https://socket.domainname.com"
        "handler": "mercure",
        "publish_origins": [
        "publisher_jwt": {
        "key": "!ChangsseMe!"
        "subscriber_jwt": {
        "key": "!ChansssgeMe!"
        "transport_url": "local://local",
        "subscriptions": true,
        "write_timeout": 0
                                                            "handle": [
        "routes": [
        "handle": [
        "handler": "metrics"
                                                            "match": [
        "path": [
        "/metrics"
                                                            "handle": [
        "handler": "static_response",
        "status_code": 200
                                                            "match": [
        "path": [
        "/healthz"
                                                            "handle": [
        "body": "Not Found",
        "status_code": 404
                                                    "handler": "file_server",
                                                    "hide": [
                                                        "/etc/caddy/CaddyFile.json"
                            "terminal": true
                    "logs": {
                        "logger_names": {
                            "mercure.work2.domainname.com": "logFiltered"
When I execute the command “caddy stop”, it gives an API error. Caddy restart or even Caddy Upgrade takes ages to get the process done, in the meantime, I have to cancel the operation and using Linux systems service to stop the caddy.
If Caddy isn’t running and listening on the admin API endpoint, then caddy stop won’t be able to stop it. That command just sends an HTTP request to the admin endpoint to ask Caddy to stop.
You probably shouldn’t use caddy stop though, you should use the systemctl commands to control Caddy. After you’ve run caddy upgrade, you can restart the service with systemctl restart caddy.
If you’re having trouble with caddy upgrade (which can happen when the build server is acting up – we can’t guarantee reliability) you can build Caddy yourself with xcaddy build --with github.com/dunglas/mercure/caddy which is what the build server does anyway.
