I’ve also posted this question on Stack Overflow
I just noticed my website wasn’t serving anymore, so I went to investigate. There’s nothing in the logs that indicates anything is wrong, and yet the server is not responding to requests on any of my hosts, except port 2015. Here’s my full Caddyfile:
direct.frederikcreemers.be, www.frederikcreemers.be {
root frederikcreemers.be/public
log
errors
git {
repo https://gitlab.com/frederikcreemers/frederikcreemers.be.git
path frederikcreemers.be
hook /pushed none
then caddy
interval 3000
hugo frederikcreemers.be
media.frederikcreemers.be, localhost:8080 {
log
errors
filemanager /manage {
no_auth
commands "git wget"
root public
browse
jwt {
path /private
redirect /login?next={path}
allow sub frederikcreemers@gmail.com
allow sub hildepeeters@gmail.com
allow sub hilde.peeters@gmail.com
allow sub elisabeth.creemers@gmail.com
allow sub elisabethcreemers@gmail.com
allow sub guidocreemers@gmail.com
jwt {
path /manage
redirect /private
login {
success_url /
logout_url /
google "client_id=foo,client_secret=bar,scope=https://www.googleapis.com/auth/userinfo.email https://www.googleapis.com/auth/plus.me"
cookie_expiry 168h
jwt_expiry 168h
creetris.frederikcreemers.be {
root creetris
errors {
404 index.html
I ran the following command to find out which applications were listening on which ports:
netstat -tulpn
And here’s the only result I got or caddy:
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp6 0 0 :::2015 :::* LISTEN 25632/caddy
I’m running caddy using systemd. Here’s the unit file:
After=network-online.target
WorkingDirectory=/home/media
Restart=on-abnormal
Environment="PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"
; Always set "-root" to something safe in case it gets forgotten in the Caddyfile.
ExecStart=/usr/local/bin/caddy -log stdout -agree=true
ExecReload=/bin/kill -USR1 $MAINPID
; Use graceful shutdown with a reasonable timeout
KillMode=mixed
KillSignal=SIGQUIT
; Unmodified caddy is not expected to use more than that.
;PrivateTmp=true
; Use a minimal /dev
;PrivateDevices=true
;ProtectSystem=full
; … except /etc/ssl/caddy, because we want Letsencrypt-certificates there.
; This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
;ReadWriteDirectories=/root/.caddy;/home/media
; They further retrict privileges that can be gained by caddy. Uncomment if you like.
NoNewPrivileges=true
Here are the logs I get for Caddy when I start it up using `systemctl start caddy``
May 01 19:20:21 ubuntu-512mb-fra1-01 systemd[1]: Started Caddy HTTP/2 web server.
May 01 19:20:21 ubuntu-512mb-fra1-01 caddy[25687]: Activating privacy features... done.
May 01 19:20:21 ubuntu-512mb-fra1-01 caddy[25687]: [WARNING] A database is going to be created for your File Manager instance at .caddy/filemanager/8f8ebb77287b3283b2cd93b625547577.db. It is highly recommended that you set th
May 01 19:20:21 ubuntu-512mb-fra1-01 caddy[25687]: [WARNING] A database is going to be created for your File Manager instance at .caddy/filemanager/96706b75e763a6accd04c4736aafe59c.db. It is highly recommended that you set th
May 01 19:20:21 ubuntu-512mb-fra1-01 caddy[25687]: [WARNING] A database is going to be created for your File Manager instance at .caddy/filemanager/a9edda69bab5269b7076ad6739f97621.db. It is highly recommended that you set th
May 01 19:20:21 ubuntu-512mb-fra1-01 caddy[25687]: [WARNING] A database is going to be created for your File Manager instance at .caddy/filemanager/ed3c77e098a98c5598578c43590134dd.db. It is highly recommended that you set th
May 01 19:20:21 ubuntu-512mb-fra1-01 caddy[25687]: [WARNING] A database is going to be created for your File Manager instance at .caddy/filemanager/d225eaa3d82bb1989154334fa90a61f0.db. It is highly recommended that you set th
May 01 19:20:22 ubuntu-512mb-fra1-01 caddy[25687]: From https://gitlab.com/frederikcreemers/frederikcreemers.be
May 01 19:20:22 ubuntu-512mb-fra1-01 caddy[25687]: * branch master -> FETCH_HEAD
May 01 19:20:23 ubuntu-512mb-fra1-01 caddy[25687]: Already up-to-date.
May 01 19:20:23 ubuntu-512mb-fra1-01 caddy[25687]: 2018/05/01 19:20:23 https://gitlab.com/frederikcreemers/frederikcreemers.be.git pulled.
May 01 19:20:23 ubuntu-512mb-fra1-01 caddy[25687]: Activating privacy features... done.
May 01 19:20:23 ubuntu-512mb-fra1-01 caddy[25687]: http://:2015
I don’t see anything that could explain my issue. The filemanager warning is because I haven’t specified a database, but that’s because I’m using the login
plugin rather than filemanager’s built-in authentication system.
Any idea what’s going on here, or what I should do to further investigate the issue?
