1. Caddy version:
Docker`
Ubuntu 20.04
Docker version 20.10.18, build b40c2f6
caddy
version: '3'
# https://hub.docker.com/_/caddy
# https://caddyserver.com/docs/quick-starts/reverse-proxy
# Running Caddy as command
image: caddy:v2.4.5
build:
context: .
dockerfile: Dockerfile
command: caddy run -config /etc/caddy/Caddyfile
ACME_AGREE: "true"
# We directly bind to the host ports and there is no Docker network here
network_mode: host
- $PWD/data:/data
- $PWD/data/config:/config
- $PWD/index.html:/usr/share/caddy/index.html
- $PWD/logs:/var/log/caddy # shared volume with caddy
- /home/docs/html:/docs # For docs static hosting
# Logstash logging for caddy from Json logs
caddy-logstash:
image: logstash:8.2.0
container_name: caddy-logstash
network_mode: host
env_file:
- ~/oracle.env
# elastisearch login vars
ECS_SERVER: ${ECS_SERVER}
ECS_USER: ${ECS_USER}
ECS_PASSWORD: ${ECS_PASSWORD}
- "5044:5044"
- "5000:5000/tcp"
- "5000:5000/udp"
- "9600:9600"
- ./logstash/config/logstash.yml:/usr/share/logstash/config/logstash.yml:ro,Z
- ./logstash/pipeline:/usr/share/logstash/pipeline:ro,Z
- $PWD/logs:/data/logs #shared volume
depends_on:
- caddy
# Caddy configuration for Trading Strategy website/backend APIs.
# Contains both production and staging environments.
# Disable the Caddy admin API
# This is personal preference, you can remove this if desired
admin off
email no-reply@tradingstrategy.ai
format json
# Production frontend and backend and docs
# PYramid backend API server is localhost:3456
# SvelteKit Node.js frontend SSR server is localhost:3000
http://example.com {
# Backend API request
handle /api* {
# This is the upstream Waitress server
reverse_proxy 127.0.0.1:3456 {
# Backend API must respond to an individual API call under 20s seconds
response_header_timeout 20s
# Special URL endpoint for Google and other bots
# that are robots.txt blocked from API
handle_path /sitemap/* {
# Same as /api, just a path rewrite using Caddy handle_path
# https://webinstall.dev/caddy/
rewrite * /api{path}
# Serve docs as files rsync'ed to the server
# See trading-strategy/.github/workflows/rsync-docs.yml for more details
# https://caddy.community/t/caddy-file-server-browse-not-working-when-root-a-specific-directory/15342/3
redir /docs /docs/
handle_path /docs* {
# See docker-compose
# mapped to /home/docs/html
root * /docs
# SvelteKit production server from frontend repository
reverse_proxy 127.0.0.1:3000 {
# Frontend must render the page under 20 seconds
# Set the default 404 page
# https://caddyserver.com/docs/caddyfile/directives/handle_errors
handle_errors {
respond "{http.error.status_code} {http.error.status_text}"
# Create a log file.
# This is mapped to local FS thru docker-compose, so you can read it like
# tail -f logs/access.log | jq
# but it is also consumed by logstash log forwarder
format json
#output stdout
# Caddy cannot have two log outputs at the same time
Caddy connection reverse proxy fails for < 1% requests randomly. I would like to pin point the underlying cause (fault in Caddy, fault in operating system, fault in the upstream web server). This is on a Docker setup using localhost connections, so network issues can be ruled out.
I traced down the request to the upstream server using CloudFlare ray headers. It seems that the upstream web server never sees the request, which is natural because the error is 502 Bad Gateway.
I could not find out how to extract the underlying operating system error reason behind HTTP 502 responses Caddy is serving. Does Caddy have any sort of error logs where underlying error reasons would be logged and how would this be turned on? As the error reason could be related to timeout, sockets, etc.
I do not see anything relevant in the access log JSON or stdout output.
The problem is that there is no error messages in Caddy output or logs.
