1. Caddy version:
v2.6.2 h1:wKoFIxpmOJLGl3QXoo6PNbYvGW4xLEgo32GPBEjWL8o
I installed caddy with Homebrew
MacOs, m1
Not using one
leptos.localhost {
reverse_proxy 127.0.0.1:3000
This setup seems to work as I expect when loaded through a browser via user navigation. But there’s also a websocket connection that can trigger a page reload via a script tag, and that always fails with a 502 error. If you manually reload it though, it shows the page again
2023/02/05 17:44:10.809 ERROR http.log.error EOF {"request": {"remote_ip": "::1", "remote_port": "59248", "proto": "HTTP/2.0", "method": "GET", "host": "leptos.localhost", "uri": "/", "headers": {"Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"], "Referer": ["https://leptos.localhost/"], "Dnt": ["1"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/109.0.0.0 Safari/537.36"], "Sec-Ch-Ua": ["\"Not_A Brand\";v=\"99\", \"Google Chrome\";v=\"109\", \"Chromium\";v=\"109\""], "Sec-Ch-Ua-Mobile": ["?0"], "Sec-Fetch-Site": ["same-origin"], "Accept-Language": ["en-US,en;q=0.9"], "Pragma": ["no-cache"], "Upgrade-Insecure-Requests": ["1"], "Sec-Fetch-Dest": ["document"], "Accept-Encoding": ["gzip, deflate, br"], "Sec-Gpc": ["1"], "Sec-Ch-Ua-Platform": ["\"macOS\""], "Sec-Fetch-Mode": ["navigate"], "Cache-Control": ["no-cache"]}, "tls": {"resumed": true, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "leptos.localhost"}}, "duration": 0.003019375, "status": 502, "err_id": "u4a5b67yu", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
I spent some time trying to figure out if this is some kind of https thing, as without the reverse proxy, the page reloads as you would expect. But I’m mostly grasping at straws here.
Here is a link to the relevant websockets code that does the page reloading:
