Hello all! I am unable to setup my Caddyfile
to work with a React SPA app such that
- React router routes works
- Calls to
/api/
(e.g.example.com/api/foo
) are properly reverse proxied to another location
With my current Caddyfile
below, React router appears to be working (visiting mysite.com/faq
does not give a 404) but calls to the API backend (e.g. mysite.com/api/foo
) appears to be trying to load a React Router route.
How can we fix this Caddyfile
www.example.com {
redir https://example.com{uri}
example.com {
root * /root/example/frontend/build
encode gzip zstd
reverse_proxy /api/* api.example.com:8000
try_files {path} /index.html
tls admin@example.com
output file /root/example/logs/access.log {
roll_size 100mb
roll_keep 5
roll_keep_for 720h
Update: This second Caddyfile
does not work too, React router no longer works, getting an error 404 when visiting https://example.com/faq
. However, reverse proxy appears to be partially working: The API server is getting hits when we visit https://example.com/api/foo
, but its getting them incorrectly as http://api.example.com:8000/api/foo
instead of http://api.example.com:8000/foo
www.example.com {
example.com {
encode gzip zstd
@notAPI {
not {
path /api/*
file {
try_files {path} {path}/ /index.html?{query}
rewrite @notAPI {http.matchers.file.relative}
roll_size 100mb
roll_keep 5
roll_keep_for 720h
Using Caddy v2.4.3
Caddy is started using caddy start --config ~/foo/Caddyfile
