I’m attempting to run Caddy as a proxy and have it setup to run with an upstart script on ubuntu 14.04 on AWS. I run the setcap on bootup to bind 80 and 443, however when the upstart config runs, it is repeatedly terminating then restarting with the lines below logging to syslog:
Jan 16 15:01:21 ip-x-x-x-x kernel: [ 1277.213855] init: caddy main process (5386) terminated with status 1 Jan 16 15:01:21 ip-x-x-x-x kernel: [ 1277.213865] init: caddy main process ended, respawning
However, when i run the command manually via command line, it runs perfectly fine and proxy’s as expected. Below is my caddy.conf file:
description "Caddy HTTP/2 web server"
start on runlevel [2345]
stop on runlevel [016]
console log
setuid www-data
setgid www-data
respawn
respawn limit 10 5
reload signal SIGUSR1
limit nofile 8192 8192
script
exec /opt/caddy/caddy_linux_amd64 -agree -email=email@email.com -log=/var/log/syslog -conf=/etc/caddy/Caddyfile
end script
for reference, below is my Caddyfile. It is updated every 5 minutes via another process (so subdomains can be added dynamically), which then also reloads caddy (via sigusr1 call) to use to the latest configuration.
http://subdomain.url1.com {
redir https://subdomain.url1.com{uri}
https://subdomain.url1.com {
max_certs 10
proxy / subdomain.url2.io {
header_upstream Host subdomain.url2.io
Could there be something missing in my config file?
