1. Output of caddy version
Ubuntu 20.04.4 LTS (GNU/Linux 5.4.0-122-generic x86_64)
systemctl start caddy
After=network.target
OnFailure=crashmailserv@%n.service
StartLimitIntervalSec=10
StartLimitBurst=5
ExecStartPost=+/bin/systemctl start upmailserv@%n.service
Environment=DO_AUTH_TOKEN=redacted
Restart=always
(gen) {
try_files {path} {path}.html
php_fastcgi unix//var/run/php/php8.1-fpm.sock
handle_errors {
rewrite * /{http.error.status_code}
reverse_proxy https://http.cat {
header_up Host http.cat
format console
output file /var/log/caddy.log {
roll_size 25mb
roll_keep 20
roll_keep_for 720h
(e-gen) {
respond /seed/* "Gone" 410 {
close
respond /nh/* "Gone" 410 {
close
handle_errors {
format console
roll_size 25mb
roll_keep 20
roll_keep_for 720h
(dns) {
dns digitalocean redacted
(header-gen) {
Strict-Transport-Security "max-age=31536000; includeSubdomains; preload"
X-Frame-Options "DENY"
(bfm-header) {
Cache-Control: no-cache, must-revalidate
eiphax.tech {
Strict-Transport-Security "max-age=31536000; preload"
root * /var/www/eipmain/webroot
import e-gen
facts.eiphax.tech {
import header-gen
root * /var/www/eipmain/facts
import gen
laundry.eiphax.tech {
import header-gen
root * /var/www/eipmain/webroot/laundry
import gen
soultrader.net.au {
import header-gen
root * /var/www/st
import gen
blog.eiphax.tech {
import header-gen
root * /var/www/blog
import gen
bytes.eiphax.tech {
import header-gen
root * /var/www/bytes
import gen
album.eiphax.tech {
import header-gen
root * /var/www/lychee/public
import gen
bin.eiphax.tech {
import header-gen
root * /var/www/eipbin
import gen
3ds.eiphax.tech {
@ytbad {
header Referer *youtube.com*
@ytbad2 {
header Referer *youtu.be*
rewrite @ytbad /youtube.html
rewrite @ytbad2 /youtube.html
import header-gen
root * /var/www/eipmain/3ds
import gen
http://wiiu.eiphax.tech {
@ytbad {
@ytbad2 {
root * /var/www/eipmain/wiiu
import gen
https://wiiu.eiphax.tech {
@ytbad {
@ytbad2 {
root * /var/www/eipmain/wiiu/resources
import gen
import header-gen
nx.eiphax.tech {
@ytbad {
@ytbad2 {
import header-gen
root * /var/www/eipmain/nx
import gen
nintendohomebrew.com {
handle_errors {
root * /var/www/eipmain/nh
close
import gen
http://bhax.nintendohomebrew.com {
root * /var/www/bhax/web/nbhax
bfm.nintendohomebrew.com, seedminer.hacks.guide {
import bfm-header
root * /var/www/eipmain/nh/seed
reverse_proxy localhost:8082
handle_errors {
level error
format console
output file /var/log/bfm_error.log {
roll_size 25mb
roll_keep 20
roll_keep_for 720h
http://part1dumper.nintendohomebrew.com https://part1dumper.nintendohomebrew.com {
reverse_proxy localhost:8081
shitpost.lol {
import header-gen
root * /var/www/sp
import gen
hacc.me please.hacc.me {
import header-gen
root * /var/www/hacc
import gen
friigaemsworld.com {
import header-gen
root * /var/www/frigam
import gen
uwu.tax {
import header-gen
root * /var/www/uwu
import gen
conversation.id {
import header-gen
root * /var/www/conv
import gen
puebes.com {
import header-gen
root * /var/www/puebes
import gen
four.family {
import header-gen
root * /var/www/four
import gen
230421.wedding {
import header-gen
root * /var/www/wedding
import gen
photos.230421.wedding {
import header-gen
root * /mnt/wedding/lychee/public
import gen
easymail.sydney {
import header-gen
root * /var/www/easymail
import gen
durriesberg.biz {
import header-gen
root * /var/www/dberg
import gen
news.eiphax.tech {
import header-gen
root * /var/www/news
import gen
blep.co {
import header-gen
root * /var/www/blep
import gen
deadletters.club {
import header-gen
root * /var/www/deadletters
import gen
photos.four.family {
import header-gen
root * /mnt/charlie/public
import gen
photos.moonaglio.wedding photos.agliomoon.wedding moonaglio.wedding agliomoon.wedding {
import header-gen
root * /var/www/moonaglio/public
import gen
I’m trying to serve/access PHP files which are really just HTML, but using PHP for things like static headers/footers. PHP FastCGI is enabled for all configs, as far as I am aware, and seems to be working (see https://bfm.nintendohomebrew.com for an example). However, when a ‘simple’ HTML file is asked to use ‘simple’ PHP (example <?php include "file.php" ?>
inside an otherwise valid HTML file), it just serves the index.php page repeatedly even when requestedfile.php does exist in the root directory.
ex/\\think\\app/invokefunction&function=call_user_func_array&vars[0]=md5&vars[1][]=HelloThinkPHP21"],"Content-Type":[],"Server":["Caddy"],"Connection":["close"]}}
Aug 25 11:10:51 eiphax.tech caddy[893607]: {"level":"info","ts":1661389851.3388712,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"66.249.66.152","remote_port":"61587","proto":"HTTP/1.1","method":"GET","host":"seedminer.hacks.guide","uri":"/","headers":{"Connection":["keep-alive"],"Accept":["*/*"],"From":["googlebot(at)googlebot.com"],"User-Agent":["Mozilla/5.0 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)"],"Accept-Encoding":["gzip, deflate, br"]}},"user_id":"","duration":0.000088925,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https://seedminer.hacks.guide/"],"Content-Type":[]}}
Aug 25 11:17:03 eiphax.tech caddy[893607]: {"level":"info","ts":1661390223.8720078,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"185.7.214.117","remote_port":"48406","proto":"HTTP/1.1","method":"GET","host":"157.230.80.146:80","uri":"/?a=fetch&content=<php>die(@md5(HelloThinkCMF))</php>","headers":{"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36"],"Content-Type":["application/json"],"Accept-Encoding":["gzip"],"Connection":["close"]}},"user_id":"","duration":0.001043372,"size":0,"status":308,"resp_headers":{"Content-Type":[],"Server":["Caddy"],"Connection":["close"],"Location":["https://157.230.80.146/?a=fetch&content=<php>die(@md5(HelloThinkCMF))</php>"]}}
Aug 25 11:18:46 eiphax.tech caddy[893607]: {"level":"info","ts":1661390326.342574,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"185.21.216.169","remote_port":"51106","proto":"HTTP/1.1","method":"GET","host":"157.230.80.146","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36"],"Accept":["*/*"],"Accept-Encoding":["gzip"]}},"user_id":"","duration":0.000075451,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https://157.230.80.146/"],"Content-Type":[]}}
Aug 25 11:18:57 eiphax.tech caddy[893607]: {"level":"info","ts":1661390337.2292178,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"40.77.167.101","remote_port":"51840","proto":"HTTP/1.1","method":"GET","host":"230421.wedding","uri":"/robots.txt","headers":{"Connection":["Keep-Alive"],"Accept":["*/*"],"Cache-Control":["no-cache"],"Pragma":["no-cache"],"Accept-Encoding":["gzip, deflate"],"From":["bingbot(at)microsoft.com"],"User-Agent":["Mozilla/5.0 (compatible; bingbot/2.0; +http://www.bing.com/bingbot.htm)"]}},"user_id":"","duration":0.000067766,"size":0,"status":308,"resp_headers":{"Location":["https://230421.wedding/robots.txt"],"Content-Type":[],"Server":["Caddy"],"Connection":["close"]}}
Aug 25 11:19:00 eiphax.tech caddy[893607]: {"level":"info","ts":1661390340.6366103,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"157.55.39.59","remote_port":"12096","proto":"HTTP/1.1","method":"GET","host":"230421.wedding","uri":"/","headers":{"From":["bingbot(at)microsoft.com"],"Cache-Control":["no-cache"],"Pragma":["no-cache"],"Accept-Encoding":["gzip, deflate"],"User-Agent":["Mozilla/5.0 (compatible; bingbot/2.0; +http://www.bing.com/bingbot.htm)"],"Connection":["Keep-Alive"],"Accept":["*/*"]}},"user_id":"","duration":0.000062659,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https://230421.wedding/"],"Content-Type":[]}}
Aug 25 11:24:30 eiphax.tech caddy[893607]: {"level":"info","ts":1661390670.4957132,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"66.249.66.157","remote_port":"59258","proto":"HTTP/1.1","method":"GET","host":"four.family","uri":"/","headers":{"If-Modified-Since":["Sat, 20 Aug 2022 03:52:12 GMT"],"Connection":["keep-alive"],"Accept":["text/html,application/xhtml+xml,application/signed-exchange;v=b3,application/xml;q=0.9,*/*;q=0.8"],"From":["googlebot(at)googlebot.com"],"User-Agent":["Mozilla/5.0 (Linux; Android 6.0.1; Nexus 5X Build/MMB29P) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.5112.79 Mobile Safari/537.36 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)"],"Amp-Cache-Transform":["google;v=\"1..8\""],"Accept-Encoding":["gzip, deflate, br"]}},"user_id":"","duration":0.000298645,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https://four.family/"],"Content-Type":[]}}
Not much. I’m a little out of my depth in regards to what PHP is actually doing, beyond that I’m aware most PHP apps serve everything from a single index.php but that’s not what my site’s doing. I assume I’ve screwed up some part of the config.
Looking into the FastCGI option, it seems like requestedfile.php
should be served when it exists, and falling back to serving index.php
at /requestedfile.php
should only happen if requestedfile.php
doesn’t exist.
