1. Output of caddy version
Downloaded from Download Caddy
Using Linux amd64
Selected mhold/caddy-ratelimit plugin
$ ./caddy run
Ubuntu 22.04
./caddy run
order rate_limit before basicauth
rate_limit {
distributed
zone static_example {
key static
events 100
window 1m
zone dynamic_example {
key {remote_host}
events 2
window 5s
respond "I'm behind the rate limiter!"
Attempting to run the sample code here: GitHub - mholt/caddy-ratelimit: HTTP rate limiting module for Caddy 2
$ ./caddy run
2022/11/06 16:28:35.717 INFO using adjacent Caddyfile
Error: adapting config using caddyfile: Caddyfile:6: unrecognized directive: distributed
Simplified the config, still no good.
rate_limit {
zone test {
key {remote_host}
events 2
window 5s
$ ./caddy run
Error: adapting config using caddyfile: Caddyfile:6: unrecognized directive: zone
