I am hosting multiple domains on the same server. Some of those domains are using Cloudflare and an Origin Certificate, while other domains are direct to the server and using an caddy-managed ACME certificate.
The Cloudflare Origin Certificate includes a wildcard entry for *.minimachines.net
Here is the relevant Caddy config:
www.minimachines.net {
tls /etc/caddy/cloudflare-origin-mm-certificate.pem /etc/caddy/cloudflare-origin-mm-key.pem
root * /home/minimachines/public_html
forum.minimachines.net {
The intend is to have the Cloudflare Origin Certificate for www.minimachines.net
, and have forum.minimachines.net
use a Caddy-managed ACME certificate.
But Caddy uses the Cloudflare Origin Certificate for forum.minimachines.net
even if it is only configured for www.minimachines.net
, most likely because this certificate is valid for *.minimachines.net
Is there a way to force Caddy to only use the provided CF Origin Certificate for a specific list of domains, and somehow ignore the wildcard? Or to force Caddy to generate an ACME certificate for forum.minimachines.net
and use it rather than the wildcard?
curl -Lvvk -o /dev/null https://forum.minimachines.net/
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Host forum.minimachines.net:443 was resolved.
* IPv6: 2001:41d0:203:247b::
* IPv4: 54.37.83.123
* Trying [2001:41d0:203:247b::]:443...
* Connected to forum.minimachines.net (2001:41d0:203:247b::) port 443
} [327 bytes data]
* (304) (IN), TLS handshake, Server hello (2):
{ [122 bytes data]
* (304) (IN), TLS handshake, Unknown (8):
{ [15 bytes data]
* (304) (IN), TLS handshake, Certificate (11):
{ [1213 bytes data]
* (304) (IN), TLS handshake, CERT verify (15):
{ [264 bytes data]
* (304) (IN), TLS handshake, Finished (20):
{ [36 bytes data]
* (304) (OUT), TLS handshake, Finished (20):
} [36 bytes data]
* SSL connection using TLSv1.3 / AEAD-CHACHA20-POLY1305-SHA256 / [blank] / UNDEF
* ALPN: server accepted h2
* subject: O=CloudFlare, Inc.; OU=CloudFlare Origin CA; CN=CloudFlare Origin Certificate
* start date: Jun 25 09:24:00 2024 GMT
* expire date: Jun 22 09:24:00 2039 GMT
* issuer: C=US; O=CloudFlare, Inc.; OU=CloudFlare Origin SSL Certificate Authority; L=San Francisco; ST=California
* SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://forum.minimachines.net/
* [HTTP/2] [1] [:method: GET]
* [HTTP/2] [1] [:authority: forum.minimachines.net]
* [HTTP/2] [1] [:path: /]
* [HTTP/2] [1] [user-agent: curl/8.6.0]
* [HTTP/2] [1] [accept: */*]
> GET / HTTP/2
> Host: forum.minimachines.net
> User-Agent: curl/8.6.0
< HTTP/2 200
Debian, systemd, using the caddy packages
systemctl start caddy
Standard from package
# Minimum reproduction config
root * /home/minimachines/forum/public_html
