Caddy on Machine running Multiple IPS
I cannot get Caddy to work after setting up multiple IPs
it spits out the error below
 serving initial configuration
Error: dialing confirmation address: dial tcp 127.0.0.1:56193: connectex: The requested address is not valid in its context.
Error: caddy process exited with error: exit status 1
PS C:\Users\Russe\Documents\Caddy>
  1. I don’t know where to find this
  2. Windows 11, just typing caddy start
You didn’t share your config or your logs, so I can’t do much to help.
Please fill out the help topic template. You can edit your post.
Run caddy version.
