from service caddy start
Linux mobydick 4.9.0-13-amd64 #1 SMP Debian 4.9.228-1 (2020-07-05) x86_64 GNU/Linux
paste command here
mgmt.hasi.pl {
output file /var/log2/services_mgmt.log {
roll_size 1gb
roll_keep 5
root * /opt/wordpress/wp
php_fastcgi 0.0.0.0:9005
docker-compose.yml
version: '3.1'
wordpress:
image: wordpress:fpm
restart: always
- 0.0.0.0:9005:9000
WORDPRESS_DB_HOST: db
WORDPRESS_DB_USER: exampleuser
WORDPRESS_DB_PASSWORD: examplepass
WORDPRESS_DB_NAME: exampledb
- /opt/wordpress/wp:/var/www/html
db:
image: mysql:5.7
restart: always
MYSQL_DATABASE: exampledb
MYSQL_USER: exampleuser
MYSQL_PASSWORD: examplepass
MYSQL_RANDOM_ROOT_PASSWORD: '1'
- db:/var/lib/mysql
wordpress:
db:
Wordpress not loading.
wordpress_1 | 192.168.5.1 - 14/Jan/2021:19:00:45 +0000 “GET /index.php” 404
The Problem iam having is that i always get an 404 if i try to access the site.
if i try to load readme.html it does work. but not the wp-admin/install.php nor index.php.
The normal procedure would be to run Caddy within the same docker-compose setting and share a unix socket, but i need Caddy 2 to do also some reverse proxy stuff for my other hosts.
Thanks in Advance
