More logs:
(all of them: dpaste: 6FUNEE4QB)
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753378985.0866601,"logger":"tls.obtain","msg":"acquiring lock","identifier":"app.sitehydrator.com"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753378985.0876732,"logger":"tls.obtain","msg":"lock acquired","identifier":"app.sitehydrator.com"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753378985.087865,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"app.sitehydrator.com"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753378985.098776,"logger":"tls","msg":"waiting on internal rate limiter","identifiers":["app.sitehydrator.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753378985.0988023,"logger":"tls","msg":"done waiting on internal rate limiter","identifiers":["app.sitehydrator.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753378985.5968826,"msg":"trying to solve challenge","identifier":"app.sitehydrator.com","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753378985.9346452,"msg":"challenge failed","identifier":"app.sitehydrator.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:connection","title":"","detail":"143.42.2.10: Fetching http://app.sitehydrator.com/.well-known/acme-challenge/gr_xNIG86Mn4pxieMnPUYXR1OyF0zq6kUd-3IiN9FLA: Connection refused","instance":"","subproblems":null},"stacktrace":"github.com/mholt/acmez/v3.(*Client).pollAuthorization\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:557\ngithub.com/mholt/acmez/v3.(*Client).solveChallenges\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:378\ngithub.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:136\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753378985.9363914,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:connection","title":"","detail":"143.42.2.10: Fetching http://app.sitehydrator.com/.well-known/acme-challenge/gr_xNIG86Mn4pxieMnPUYXR1OyF0zq6kUd-3IiN9FLA: Connection refused","instance":"","subproblems":null},"order":"https://acme-v02.api.letsencrypt.org/acme/order/1221654447/410450454901","attempt":1,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753378987.055881,"msg":"trying to solve challenge","identifier":"app.sitehydrator.com","challenge_type":"tls-alpn-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753378987.4064052,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:connection","title":"","detail":"143.42.2.10: Connection refused","instance":"","subproblems":null},"order":"https://acme-v02.api.letsencrypt.org/acme/order/1221654447/410450462061","attempt":2,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753378987.4064827,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"app.sitehydrator.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:connection - 143.42.2.10: Connection refused"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753378987.4065187,"logger":"tls.obtain","msg":"will retry","error":"[app.sitehydrator.com] Obtain: [app.sitehydrator.com] solving challenge: app.sitehydrator.com: [app.sitehydrator.com] authorization failed: HTTP 400 urn:ietf:params:acme:error:connection - 143.42.2.10: Connection refused (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":2.318724096,"max_duration":2592000}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"warn","ts":1753379017.5307662,"logger":"tls","msg":"looking up info for HTTP challenge","host":"app.sitehydrator.com","remote_addr":"10.0.0.2:34203","user_agent":"Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753379047.40733,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"app.sitehydrator.com"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379048.0936644,"msg":"challenge failed","identifier":"app.sitehydrator.com","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: remote error: tls: internal error","instance":"","subproblems":null},"stacktrace":"github.com/mholt/acmez/v3.(*Client).pollAuthorization\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:557\ngithub.com/mholt/acmez/v3.(*Client).solveChallenges\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:378\ngithub.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:136\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379048.0947769,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: remote error: tls: internal error","instance":"","subproblems":null},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/111982664/26253595824","attempt":1,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753379049.206461,"msg":"trying to solve challenge","identifier":"app.sitehydrator.com","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379049.869552,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/kB0guoZ51v0n7aBIGjZlXe_RBiYi1gTup5ueQVBNFz4: remote error: tls: internal error","instance":"","subproblems":null},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/111982664/26253596194","attempt":2,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379049.8698134,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"app.sitehydrator.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:tls - 143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/kB0guoZ51v0n7aBIGjZlXe_RBiYi1gTup5ueQVBNFz4: remote error: tls: internal error"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379049.869884,"logger":"tls.obtain","msg":"will retry","error":"[app.sitehydrator.com] Obtain: [app.sitehydrator.com] solving challenge: app.sitehydrator.com: [app.sitehydrator.com] authorization failed: HTTP 400 urn:ietf:params:acme:error:tls - 143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/kB0guoZ51v0n7aBIGjZlXe_RBiYi1gTup5ueQVBNFz4: remote error: tls: internal error (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":2,"retrying_in":120,"elapsed":64.782089357,"max_duration":2592000}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"warn","ts":1753379078.5453293,"logger":"tls","msg":"looking up info for HTTP challenge","host":"app.sitehydrator.com","remote_addr":"10.0.0.2:49962","user_agent":"Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"warn","ts":1753379078.573912,"logger":"tls","msg":"looking up info for HTTP challenge","host":"app.sitehydrator.com","remote_addr":"10.0.0.2:58380","user_agent":"Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379170.7065487,"msg":"challenge failed","identifier":"app.sitehydrator.com","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: remote error: tls: internal error","instance":"","subproblems":null},"stacktrace":"github.com/mholt/acmez/v3.(*Client).pollAuthorization\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:557\ngithub.com/mholt/acmez/v3.(*Client).solveChallenges\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:378\ngithub.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:136\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379170.7068043,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: remote error: tls: internal error","instance":"","subproblems":null},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/111982664/26253624244","attempt":1,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753379172.1241772,"logger":"tls","msg":"served key authentication","identifier":"app.sitehydrator.com","challenge":"http-01","remote":"10.0.0.2:40041","distributed":false}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753379172.7851264,"logger":"tls","msg":"served key authentication","identifier":"app.sitehydrator.com","challenge":"http-01","remote":"10.0.0.2:25896","distributed":false}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379173.0855997,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"During secondary validation: 143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/YXPCzl1085D8Z0NCJyQbdeNwMPnpxCo7lh9mloYBfek: remote error: tls: internal error","instance":"","subproblems":null},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/111982664/26253624624","attempt":2,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379173.0857434,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"app.sitehydrator.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:tls - During secondary validation: 143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/YXPCzl1085D8Z0NCJyQbdeNwMPnpxCo7lh9mloYBfek: remote error: tls: internal error"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379173.0857666,"logger":"tls.obtain","msg":"will retry","error":"[app.sitehydrator.com] Obtain: [app.sitehydrator.com] solving challenge: app.sitehydrator.com: [app.sitehydrator.com] authorization failed: HTTP 400 urn:ietf:params:acme:error:tls - During secondary validation: 143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/YXPCzl1085D8Z0NCJyQbdeNwMPnpxCo7lh9mloYBfek: remote error: tls: internal error (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":3,"retrying_in":120,"elapsed":187.997972042,"max_duration":2592000}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379203.0895376,"logger":"tls","msg":"tls-alpn challenge","remote_addr":"10.0.0.2:32475","server_name":"app.sitehydrator.com","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753379293.0860026,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"app.sitehydrator.com"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379293.9197788,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: remote error: tls: internal error","instance":"","subproblems":null},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/111982664/26253650584","attempt":1,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"info","ts":1753379295.757492,"logger":"tls","msg":"served key authentication","identifier":"app.sitehydrator.com","challenge":"http-01","remote":"10.0.0.2:39003","distributed":false}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379297.2069538,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"During secondary validation: 143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/l2vubmF1BcFqzVybkw943beJqKUobAr1KSp8AAvf3dc: remote error: tls: internal error","instance":"","subproblems":null},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/111982664/26253650964","attempt":2,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379297.207,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"app.sitehydrator.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:tls - During secondary validation: 143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/l2vubmF1BcFqzVybkw943beJqKUobAr1KSp8AAvf3dc: remote error: tls: internal error"}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379297.207041,"logger":"tls.obtain","msg":"will retry","error":"[app.sitehydrator.com] Obtain: [app.sitehydrator.com] solving challenge: app.sitehydrator.com: [app.sitehydrator.com] authorization failed: HTTP 400 urn:ietf:params:acme:error:tls - During secondary validation: 143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/l2vubmF1BcFqzVybkw943beJqKUobAr1KSp8AAvf3dc: remote error: tls: internal error (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":4,"retrying_in":300,"elapsed":312.11924636,"max_duration":2592000}
swarm.0.odxitvobw5ys@*.79.141.245 | {"level":"error","ts":1753379325.4275837,"logger":"tls","msg":"tls-alpn challenge","remote_addr":"10.0.0.2:36023","server_name":"app.sitehydrator.com","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"info","ts":1753379015.0719967,"logger":"tls.obtain","msg":"acquiring lock","identifier":"app.sitehydrator.com"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"info","ts":1753379015.0838852,"logger":"tls.obtain","msg":"lock acquired","identifier":"app.sitehydrator.com"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"info","ts":1753379015.08416,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"app.sitehydrator.com"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"info","ts":1753379015.0874996,"logger":"tls","msg":"waiting on internal rate limiter","identifiers":["app.sitehydrator.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"warn","ts":1753379015.8466866,"logger":"tls","msg":"looking up info for HTTP challenge","host":"app.sitehydrator.com","remote_addr":"10.0.0.2:43427","user_agent":"Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379015.93504,"logger":"tls","msg":"tls-alpn challenge","remote_addr":"10.0.0.2:49123","server_name":"app.sitehydrator.com","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379015.05347,"logger":"tls.obtain","msg":"acquiring lock","identifier":"app.sitehydrator.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379015.072526,"logger":"tls.obtain","msg":"lock acquired","identifier":"app.sitehydrator.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379015.072903,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"app.sitehydrator.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379015.073691,"logger":"tls","msg":"waiting on internal rate limiter","identifiers":["app.sitehydrator.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379015.0749648,"logger":"tls","msg":"done waiting on internal rate limiter","identifiers":["app.sitehydrator.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379015.5318663,"msg":"trying to solve challenge","identifier":"app.sitehydrator.com","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"error","ts":1753379016.199817,"msg":"challenge failed","identifier":"app.sitehydrator.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/kTSpJrMKzZoi49o44cMzBiz4LYpBBzjacUsbdfz9B2I: remote error: tls: internal error","instance":"","subproblems":null},"stacktrace":"github.com/mholt/acmez/v3.(*Client).pollAuthorization\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:557\ngithub.com/mholt/acmez/v3.(*Client).solveChallenges\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:378\ngithub.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:136\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"error","ts":1753379016.1999302,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/kTSpJrMKzZoi49o44cMzBiz4LYpBBzjacUsbdfz9B2I: remote error: tls: internal error","instance":"","subproblems":null},"order":"https://acme-v02.api.letsencrypt.org/acme/order/1676612997/410450582911","attempt":1,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"error","ts":1753379017.2557652,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"app.sitehydrator.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 429 urn:ietf:params:acme:error:rateLimited - too many failed authorizations (5) for \"app.sitehydrator.com\" in the last 1h0m0s, retry after 2025-07-24 17:44:44 UTC: see https://letsencrypt.org/docs/rate-limits/#authorization-failures-per-hostname-per-account"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"error","ts":1753379017.2558448,"logger":"tls.obtain","msg":"will retry","error":"[app.sitehydrator.com] Obtain: [app.sitehydrator.com] creating new order: attempt 1: https://acme-v02.api.letsencrypt.org/acme/new-order: HTTP 429 urn:ietf:params:acme:error:rateLimited - too many failed authorizations (5) for \"app.sitehydrator.com\" in the last 1h0m0s, retry after 2025-07-24 17:44:44 UTC: see https://letsencrypt.org/docs/rate-limits/#authorization-failures-per-hostname-per-account (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":2.183178921,"max_duration":2592000}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379080.8106115,"msg":"got renewal info","names":["app.sitehydrator.com"],"window_start":1758483011,"window_end":1758638460,"selected_time":1758578009,"recheck_after":1753400680.8106039,"explanation_url":""}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379080.918318,"msg":"got renewal info","names":["app.sitehydrator.com"],"window_start":1758483011,"window_end":1758638460,"selected_time":1758511825,"recheck_after":1753400680.9183109,"explanation_url":""}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379080.919997,"logger":"tls","msg":"waiting on internal rate limiter","identifiers":["app.sitehydrator.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379080.9205968,"logger":"tls","msg":"done waiting on internal rate limiter","identifiers":["app.sitehydrator.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"error","ts":1753379081.0238419,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"app.sitehydrator.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 429 urn:ietf:params:acme:error:rateLimited - too many failed authorizations (5) for \"app.sitehydrator.com\" in the last 1h0m0s, retry after 2025-07-24 17:44:42 UTC: see https://letsencrypt.org/docs/rate-limits/#authorization-failures-per-hostname-per-account"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"error","ts":1753379081.0238903,"logger":"tls.obtain","msg":"will retry","error":"[app.sitehydrator.com] Obtain: [app.sitehydrator.com] creating new order: attempt 1: https://acme-v02.api.letsencrypt.org/acme/new-order: HTTP 429 urn:ietf:params:acme:error:rateLimited - too many failed authorizations (5) for \"app.sitehydrator.com\" in the last 1h0m0s, retry after 2025-07-24 17:44:42 UTC: see https://letsencrypt.org/docs/rate-limits/#authorization-failures-per-hostname-per-account (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":2,"retrying_in":120,"elapsed":65.95122433,"max_duration":2592000}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379201.024272,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"app.sitehydrator.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379201.1906025,"msg":"authorization finalized","identifier":"app.sitehydrator.com","authz_status":"valid"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"warn","ts":1753379201.530075,"logger":"tls","msg":"looking up info for HTTP challenge","host":"app.sitehydrator.com","remote_addr":"10.0.0.2:49433","user_agent":"Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379204.4097471,"msg":"got renewal info","names":["app.sitehydrator.com"],"window_start":1758483135,"window_end":1758638585,"selected_time":1758569939,"recheck_after":1753400804.4097385,"explanation_url":""}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379204.5175812,"msg":"got renewal info","names":["app.sitehydrator.com"],"window_start":1758483135,"window_end":1758638585,"selected_time":1758561122,"recheck_after":1753400804.5175724,"explanation_url":""}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379204.5196683,"logger":"tls","msg":"waiting on internal rate limiter","identifiers":["app.sitehydrator.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379204.5197709,"logger":"tls","msg":"done waiting on internal rate limiter","identifiers":["app.sitehydrator.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"info","ts":1753379204.6989589,"msg":"trying to solve challenge","identifier":"app.sitehydrator.com","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"error","ts":1753379205.6330407,"msg":"challenge failed","identifier":"app.sitehydrator.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/cSb9hk8ldPzxKEjsOCKtZXXuwLgPSxaH-9cmjRq4OB4: remote error: tls: internal error","instance":"","subproblems":null},"stacktrace":"github.com/mholt/acmez/v3.(*Client).pollAuthorization\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:557\ngithub.com/mholt/acmez/v3.(*Client).solveChallenges\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:378\ngithub.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:136\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:410\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"error","ts":1753379205.633191,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/cSb9hk8ldPzxKEjsOCKtZXXuwLgPSxaH-9cmjRq4OB4: remote error: tls: internal error","instance":"","subproblems":null},"order":"https://acme-v02.api.letsencrypt.org/acme/order/1676612997/410451395441","attempt":1,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:410\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"warn","ts":1753379206.4423306,"logger":"tls","msg":"looking up info for HTTP challenge","host":"app.sitehydrator.com","remote_addr":"10.0.0.2:51705","user_agent":"Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"error","ts":1753379206.689995,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"app.sitehydrator.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 429 urn:ietf:params:acme:error:rateLimited - too many failed authorizations (5) for \"app.sitehydrator.com\" in the last 1h0m0s, retry after 2025-07-24 17:56:43 UTC: see https://letsencrypt.org/docs/rate-limits/#authorization-failures-per-hostname-per-account"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"error","ts":1753379206.6900723,"logger":"tls.obtain","msg":"will retry","error":"[app.sitehydrator.com] Obtain: [app.sitehydrator.com] creating new order: attempt 1: https://acme-v02.api.letsencrypt.org/acme/new-order: HTTP 429 urn:ietf:params:acme:error:rateLimited - too many failed authorizations (5) for \"app.sitehydrator.com\" in the last 1h0m0s, retry after 2025-07-24 17:56:43 UTC: see https://letsencrypt.org/docs/rate-limits/#authorization-failures-per-hostname-per-account (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":3,"retrying_in":120,"elapsed":191.617406443,"max_duration":2592000}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"error","ts":1753379208.237425,"logger":"tls","msg":"tls-alpn challenge","remote_addr":"10.0.0.2:33265","server_name":"app.sitehydrator.com","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.n3kbjmj3w0xv@*.107.134.41 | {"level":"warn","ts":1753379295.9987612,"logger":"tls","msg":"looking up info for HTTP challenge","host":"app.sitehydrator.com","remote_addr":"10.0.0.2:64356","user_agent":"Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"info","ts":1753379025.0631964,"logger":"tls","msg":"done waiting on internal rate limiter","identifiers":["app.sitehydrator.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379025.5955942,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"app.sitehydrator.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 404 urn:ietf:params:acme:error:malformed - No such authorization"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379025.596167,"logger":"tls.obtain","msg":"will retry","error":"[app.sitehydrator.com] Obtain: [app.sitehydrator.com] solving challenge: getting authorization at https://acme-v02.api.letsencrypt.org/acme/authz/1560261627/558273559021: attempt 1: https://acme-v02.api.letsencrypt.org/acme/authz/1560261627/558273559021: HTTP 404 urn:ietf:params:acme:error:malformed - No such authorization (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":10.512045328,"max_duration":2592000}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"warn","ts":1753379078.6282747,"logger":"tls","msg":"looking up info for HTTP challenge","host":"app.sitehydrator.com","remote_addr":"10.0.0.2:47622","user_agent":"Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"warn","ts":1753379078.856043,"logger":"tls","msg":"looking up info for HTTP challenge","host":"app.sitehydrator.com","remote_addr":"10.0.0.2:48896","user_agent":"Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379086.1277406,"msg":"challenge failed","identifier":"app.sitehydrator.com","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: remote error: tls: internal error","instance":"","subproblems":null},"stacktrace":"github.com/mholt/acmez/v3.(*Client).pollAuthorization\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:557\ngithub.com/mholt/acmez/v3.(*Client).solveChallenges\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:378\ngithub.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:136\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379086.1279304,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: remote error: tls: internal error","instance":"","subproblems":null},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/135604333/26253603614","attempt":1,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379087.9020586,"msg":"challenge failed","identifier":"app.sitehydrator.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/QBHPM1Z6AzEA2xrTNU7qVfZ55qCLb6c9a5UQPvvk9J8: remote error: tls: internal error","instance":"","subproblems":null},"stacktrace":"github.com/mholt/acmez/v3.(*Client).pollAuthorization\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:557\ngithub.com/mholt/acmez/v3.(*Client).solveChallenges\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:378\ngithub.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:136\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379087.9035597,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/QBHPM1Z6AzEA2xrTNU7qVfZ55qCLb6c9a5UQPvvk9J8: remote error: tls: internal error","instance":"","subproblems":null},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/135604333/26253603984","attempt":2,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379087.904904,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"app.sitehydrator.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:tls - 143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/QBHPM1Z6AzEA2xrTNU7qVfZ55qCLb6c9a5UQPvvk9J8: remote error: tls: internal error"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379087.905045,"logger":"tls.obtain","msg":"will retry","error":"[app.sitehydrator.com] Obtain: [app.sitehydrator.com] solving challenge: app.sitehydrator.com: [app.sitehydrator.com] authorization failed: HTTP 400 urn:ietf:params:acme:error:tls - 143.42.2.10: Fetching https://app.sitehydrator.com/.well-known/acme-challenge/QBHPM1Z6AzEA2xrTNU7qVfZ55qCLb6c9a5UQPvvk9J8: remote error: tls: internal error (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":2,"retrying_in":120,"elapsed":72.82092229,"max_duration":2592000}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379170.3553221,"logger":"tls","msg":"tls-alpn challenge","remote_addr":"10.0.0.2:53669","server_name":"app.sitehydrator.com","error":"no information found to solve challenge for identifier: app.sitehydrator.com"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379208.4301722,"msg":"challenge failed","identifier":"app.sitehydrator.com","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: remote error: tls: internal error","instance":"","subproblems":null},"stacktrace":"github.com/mholt/acmez/v3.(*Client).pollAuthorization\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:557\ngithub.com/mholt/acmez/v3.(*Client).solveChallenges\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:378\ngithub.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:136\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379208.431631,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"143.42.2.10: remote error: tls: internal error","instance":"","subproblems":null},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/135604333/26253631504","attempt":1,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
swarm.0.bhtwxqxdu3en@*.228.42.26 | {"level":"error","ts":1753379209.9055119,"msg":"validating authorization","identifier":"app.sitehydrator.com","problem":
