Caddy not serving files over HTTPS
Caddy is not serving static files over https, theyre avaliable locally, curl detects them, but its not visible outside, it is not a firewall issue as the ports are open and i have tried disabling it, it does not seem like a network problem since i was hosting perfectly fine with nodejs earlier.
Mar 22 19:08:09 localhost caddy[1211611]: caddy.HomeDir=/var/lib/caddy
Mar 22 19:08:09 localhost caddy[1211611]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Mar 22 19:08:09 localhost caddy[1211611]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Mar 22 19:08:09 localhost caddy[1211611]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Mar 22 19:08:09 localhost caddy[1211611]: caddy.Version=2.6.2
Mar 22 19:08:09 localhost caddy[1211611]: runtime.GOOS=linux
Mar 22 19:08:09 localhost caddy[1211611]: runtime.GOARCH=amd64
Mar 22 19:08:09 localhost caddy[1211611]: runtime.Compiler=gc
Mar 22 19:08:09 localhost caddy[1211611]: runtime.NumCPU=1
Mar 22 19:08:09 localhost caddy[1211611]: runtime.GOMAXPROCS=1
Mar 22 19:08:09 localhost caddy[1211611]: runtime.Version=go1.19.8
Mar 22 19:08:09 localhost caddy[1211611]: os.Getwd=/
Mar 22 19:08:09 localhost caddy[1211611]: LANG=en_US.UTF-8
Mar 22 19:08:09 localhost caddy[1211611]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Mar 22 19:08:09 localhost caddy[1211611]: NOTIFY_SOCKET=/run/systemd/notify
Mar 22 19:08:09 localhost caddy[1211611]: HOME=/var/lib/caddy
Mar 22 19:08:09 localhost caddy[1211611]: LOGNAME=caddy
Mar 22 19:08:09 localhost caddy[1211611]: USER=caddy
Mar 22 19:08:09 localhost caddy[1211611]: INVOCATION_ID=df772ce7196a46e1a4f0bbd780a2a61f
Mar 22 19:08:09 localhost caddy[1211611]: JOURNAL_STREAM=8:16482715
Mar 22 19:08:09 localhost caddy[1211611]: SYSTEMD_EXEC_PID=1211611
Mar 22 19:08:09 localhost caddy[1211611]: XDG_CONFIG_HOME=/var/lib/caddy/.config
Mar 22 19:08:09 localhost caddy[1211611]: XDG_DATA_HOME=/var/lib/caddy/.local/share
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3569345,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"warn","ts":1742670489.3578742,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3666363,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3670845,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3671584,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.367848,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3682754,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3700757,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0004fbf10"}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3701055,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.371915,"logger":"tls","msg":"finished cleaning storage units"}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3719552,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3719833,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3719878,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["marcothepucci.dev"]}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3734896,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Mar 22 19:08:09 localhost caddy[1211611]: {"level":"info","ts":1742670489.3735209,"msg":"serving initial configuration"}
Installed using APT, followed the Getting Started
Debian GNU/Linux 12, kernel 6.1.0 x86
sudo systemctl start caddy.service
Type=notify
ProtectHome=false
Environment=XDG_CONFIG_HOME=/var/lib/caddy/.config
Environment=XDG_DATA_HOME=/var/lib/caddy/.local/share
marcothepucci.dev {
    root * /var/www/marcothepucci-dev
What do you mean by that? Can you share the steps or commands you used to determine this, along with their output? Also, could you post the result of:
ls -lsa /var/www/marcothepucci-dev
Heres the output of the command as you requested
total 36
4 drwxr-xr-x 7 caddy caddy 4096 Mar 22 18:12 .
4 drwxr-xr-x 5 root  root  4096 Mar 22 17:57 ..
4 drwxr-xr-x 2 caddy caddy 4096 Mar 22 17:57 assets
4 -rwxr-xr-x 1 caddy caddy  419 Mar 22 17:57 caddy.json
4 drwxr-xr-x 2 caddy caddy 4096 Mar 22 17:57 how
4 drwxr-xr-x 2 caddy caddy 4096 Mar 22 17:57 main
4 -rwxr-xr-x 1 caddy caddy 1346 Mar 22 17:57 output.log
4 drwxr-xr-x 2 caddy caddy 4096 Mar 22 17:57 scripts
4 drwxr-xr-x 2 caddy caddy 4096 Mar 22 17:57 stylesheets
Looking at it now i think i should fix my Caddyfile
As for the commands i used to determine accessibility, i forgot what i ran, but from what i can tell runnning curl marcothepucci.dev on my local machine returns:
curl: (7) Failed to connect to marcothepucci.dev port 443 after 18 ms: Couldn't connect to server
while running this on the server returns
root@localhost:~# curl https://localhost
curl: (35) OpenSSL/3.0.15: error:0A000438:SSL routines::tlsv1 alert internal error
Caddy is not configured to answer localhost, only marcothepucci.dev
Checking marcothepucci.dev, I get Connection refused. Is your firewall blocking access?
This is extremely old. Don’t use what’s provided by default by Debian/Ubuntu. The packagers aren’t in contact with us. Use our APT repo: Install — Caddy Documentation,
Thanks for the quick response, these are my firewall settings
Status: active
To                         Action      From
22/tcp                     ALLOW       Anywhere
443/tcp                    ALLOW       Anywhere
3000/tcp                   ALLOW       Anywhere
Nginx Full                 ALLOW       Anywhere
80/tcp                     ALLOW       Anywhere
8000/tcp                   ALLOW       Anywhere
22/tcp (v6)                ALLOW       Anywhere (v6)
443/tcp (v6)               ALLOW       Anywhere (v6)
3000/tcp (v6)              ALLOW       Anywhere (v6)
Nginx Full (v6)            ALLOW       Anywhere (v6)
80/tcp (v6)                ALLOW       Anywhere (v6)
8000/tcp (v6)              ALLOW       Anywhere (v6)
I doubt this could be a firewall issue as i was hosting perfectly fine on node earlier, also i followed the guide and deleted to reinstall caddy, still didn’t fix the issue, i am considering wiping my server to get rid of any issues.
Also this reply cooldown seems very annoying, does it get lower with time?
Enable debug mode for extra logging by adding this at the top:
Not really. We’re fighting aggressive Indian scammers, and the rate-limit slows them down. Their ISPs (Jio and Airtel) are not acknowledging our reports.
I enabled debug mode and it added two extra lines to the logs in systemctl status
Mar 23 11:48:17 localhost caddy[2137653]: {"level":"info","ts":1742730497.551198,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Mar 23 11:48:17 localhost caddy[2137653]: {"level":"info","ts":1742730497.5512009,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["marcothepucci.dev"]}
Mar 23 11:48:17 localhost caddy[2137653]: {"level":"info","ts":1742730497.5524836,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0000e1700"}
Mar 23 11:48:17 localhost caddy[2137653]: {"level":"info","ts":1742730497.5560942,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy/.local/share/caddy","instance":"3560a36f-2767-4354-a918-26d2816201d6","try_again":1742816897.5560935,"try_again_in":86399.99999976}
Mar 23 11:48:17 localhost caddy[2137653]: {"level":"info","ts":1742730497.55614,"logger":"tls","msg":"finished cleaning storage units"}
Mar 23 11:48:17 localhost caddy[2137653]: {"level":"debug","ts":1742730497.557356,"logger":"tls.cache","msg":"added certificate to cache","subjects":["marcothepucci.dev"],"expiration":1750439036,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"74c5817fcaf1ad6d8c9728a61fd535445aabf80f9a43ba24c7c9d4d3ab1ad8a3","cache_size":1,"cache_capacity":10000}
Mar 23 11:48:17 localhost caddy[2137653]: {"level":"debug","ts":1742730497.5573807,"logger":"events","msg":"event","name":"cached_managed_cert","id":"640b9236-fe94-4c40-96fa-21f4fe1bd590","origin":"tls","data":{"sans":["marcothepucci.dev"]}}
Mar 23 11:48:17 localhost caddy[2137653]: {"level":"info","ts":1742730497.5574865,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Mar 23 11:48:17 localhost caddy[2137653]: {"level":"info","ts":1742730497.5575285,"msg":"serving initial configuration"}
Mar 23 11:48:17 localhost systemd[1]: Started caddy.service - Caddy.
That’s not enough. Make a request and share the logs it prints. If no logs show up, the request didn’t reach Caddy.
I tried making a request, nothing in logs, as you said the request is not reachind caddy, im seriously considering wiping everything.
Mar 23 16:49:13 localhost caddy[2335500]: {"level":"warn","ts":1742748553.3068743,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
Mar 23 16:49:13 localhost caddy[2335500]: {"level":"info","ts":1742748553.3068771,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Mar 23 16:49:13 localhost caddy[2335500]: {"level":"info","ts":1742748553.306881,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["marcothepucci.dev"]}
Mar 23 16:49:13 localhost caddy[2335500]: {"level":"debug","ts":1742748553.307934,"logger":"tls.cache","msg":"added certificate to cache","subjects":["marcothepucci.dev"],"expiration":1750439036,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"74c5817fcaf1ad6d8c9728a61fd535445aabf80f9a43ba24c7c9d4d3ab1ad8a3","cache_size":1,"cache_capacity":10000}
Mar 23 16:49:13 localhost caddy[2335500]: {"level":"debug","ts":1742748553.30803,"logger":"events","msg":"event","name":"cached_managed_cert","id":"b35180d9-d7aa-40f4-9e45-228486be8803","origin":"tls","data":{"sans":["marcothepucci.dev"]}}
Mar 23 16:49:13 localhost caddy[2335500]: {"level":"info","ts":1742748553.308707,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Mar 23 16:49:13 localhost caddy[2335500]: {"level":"info","ts":1742748553.308837,"msg":"serving initial configuration"}
Mar 23 16:49:13 localhost caddy[2335500]: {"level":"info","ts":1742748553.3101819,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy/.local/share/caddy","instance":"3560a36f-2767-4354-a918-26d2816201d6","try_again":1742834953.3101811,"try_again_in":86399.99999968}
Mar 23 16:49:13 localhost caddy[2335500]: {"level":"info","ts":1742748553.3102648,"logger":"tls","msg":"finished cleaning storage units"}
Mar 23 16:49:13 localhost caddy[2335500]: {"level":"info","ts":1742748553.3104062,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00033f980"}```
Is the DNS configuration correct?
As i mentioned previously, i was hosting on nodejs perfectly fine, and i have made sure to double check my DNS settings, everything is correct.
Can you run the following command on your server? Just want to see what’s listening on ports 80 and 443
sudo lsof -i :80 -i :443 -sTCP:LISTEN
Its just caddy
root@localhost:~# sudo lsof -i :80 -i :443 -sTCP:LISTEN
COMMAND     PID  USER   FD   TYPE    DEVICE SIZE/OFF NODE NAME
caddy   3850069 caddy    6u  IPv6 365727880      0t0  TCP *:https (LISTEN)
caddy   3850069 caddy    8u  IPv6 365727882      0t0  TCP *:http (LISTEN)
If your server directly exposed to the Internet or is there a router or something else forwarding the ports 80 and 443 to your Caddy?
found the issue, i had forgotten to delete the rule that forwards 443 traffic to port 3000, thanks for the help!
