Hi everyone,
I setup caddy server (0.10.10) on an AWS instance running Ubuntu a couple of weeks ago and everything seemed to be working fine. I’m serving a couple of static sites as well as reverse proxying a couple of apps using caddy, and now I have automatic TLS! Yay! (Also I really like the http2)
Anyway, while I remember testing this and it working initially, today I’ve noticed that http redirects don’t seem to be working. I might have tested this the wrong way by using a web browser instead of using curl (initially) but now when I curl to a domain that I own I simply get “connection refused” every time.
The way I understand it, I should get a redirect to the https version of the domain. If that’s not the default behavior, then please let me know how to configure that behavior. I have tried several alternate configurations, including specifying http://domain… and using redir. Nothing has worked. HTTPS is working for all of my domains, which is great, but http redirects are simply not working. Any help is appreciated!
Caddyfile:
fishincoach.com www.fishincoach.com {
tls tom@tomutley.com
root /home/ubuntu/web/fishincoach
log fishincoach.access.log
# (repeat same pattern for static sites)
foundirl.com www.foundirl.com {
push
proxy / http://localhost:6000
log foundirl.access.log
# (repeat same pattern for proxy sites)
Netstat:
sudo netstat -tlp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 localhost:27017 : LISTEN 1048/mongod
tcp 0 0 :ssh : LISTEN 1053/sshd
tcp 0 0 localhost:5500 : LISTEN 21709/server.js
tcp6 0 0 [::]:http [::]: LISTEN 6120/caddy
tcp6 0 0 [::]:x11 [::]:* LISTEN 30514/foundirl
tcp6 0 0 [::]:ssh [::]:* LISTEN 1053/sshd
tcp6 0 0 [::]:https [::]:* LISTEN 6120/caddy
