1. Output of caddy version
v2.5.2
I’ve a Caddyfile that I run with caddy start
on my VPS
I use Arch btw
caddy start
no
pp.sunney.dev {
@plausible path /js/script.js /api/event
handle @plausible {
rewrite /js/script.js /js/script.js
reverse_proxy https://analytics.sunney.dev {
reverse_proxy localhost:8000
I’m trying to redirect requests from pp.sunney.dev
to analytics.sunney.dev
on the following paths:
/api/event
/js/script.js
It works, but instead of passing the actual remote’s IP address, it passes it’s own (my own VPS’s IP address on the X-Forwarded-For
header)
What received headers look like when I’m sending the request from my Chrome Browser:
(removed some headers that were not related to this problem)
host: 'pp.sunney.dev:443',
'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36',
'x-forwarded-for': '88.99.124.77', // MY VPS IP
'x-forwarded-host': 'pp.sunney.dev:443',
'x-forwarded-proto': 'https'
But, x-forwarded-host
above should be my actual IP, that I sent the request from, not my VPS’s IP.
Hope you understand the issue I’m having.
No errors
Plausible docs on the Caddyfile I used.
