Caddy load balancing does not work
1. Output of caddy version: v2.6.1
2. How I run Caddy: docker container.
a. System environment: VM: Linux sles 15, Docker Server Version: 20.10.17-ce
version: "3.7"
    image: caddy:2.6.1
    restart: always
    build:
     context: .
     dockerfile: Dockerfile
     - "/opt/docker/monitoring/caddy/Caddyfile:/etc/caddy/Caddyfile"
     - "/opt/docker/monitoring/caddy/data/caddy:/data"
     - "/opt/docker/monitoring/caddy/config:/config"
     - "/opt/docker/monitoring/caddy/log/:/var/log/"
    labels:
      logging: "promtail"
      logging_jobname: "containerlogs"
     - monitoring
 monitoring:
    external: true
{        [43/1095]
  email     ci@example.com
  acme_ca   https://acme.example.com:9001/acme/acme/directory
#  ca_root   /usr/local/share/ca-certificates/ca_bundle.crt
#(logfile) {
#log {
#    level info
#    output file /var/log/mimir.log {
#        roll_size 10MiB
#        roll_keep 5
#        roll_keep_for 120h
#       format json {
#         time_format iso8601
(logconsole) {
        output stdout
        format json {
         time_format iso8601
grafana.example.com {
          reverse_proxy grafana:3000
prometheus.example.com {
          reverse_proxy prometheus:9090
          basicauth /* {
            admin JDJhJDE0JEs3YWdTQm52cllTcnFPU2JVZĂ–LAJSDFĂ–ASO"WNASByc3JpV0JVbHZmMnkuMkpQT1MzeXJSWnhT
promtail.example.com {
          reverse_proxy promtail:9080
          basicauth /* {
telegraf.example.com {
          reverse_proxy telegraf:9274
          basicauth /* {
loki.example.com {
          reverse_proxy loki:3100
          basicauth /* {
mimir.example.com {
            import logconsole
            reverse_proxy * {
            to mimir-1:8080
            to mimir-2:8080
            to mimir-3:8080
            lb_policy round_robin
            lb_try_duration 1s
            lb_try_interval 250s
            max_fails 1
I have replicated Grafana Mimir, as load balancer I have used Caddy. When the Mimir containers are running everything works fine, as soon as one of the Mimir instances is killed, none of the containers are reachable.
I tested this with ngix to isolate the problem and to know if the problem is with the Mimir. With ngix, it works beautifully. I have tested all the “lb_policy”. Without success.
2023-01-17T11:15:20+01:00	{"level":"info","ts":"2023-01-17T10:15:20.038Z","logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"User-Agent":["Prometheus/2.37.4"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Scope-Orgid":["mimir"],"Content-Length":["58949"],"Content-Encoding":["snappy"],"Content-Type":["application/x-protobuf"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"user_id":"","duration":0.008772353,"size":0,"status":200,"resp_headers":{"Date":["Tue, 17 Jan 2023 10:15:20 GMT"],"Content-Length":["0"],"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"]}}
2023-01-17T11:15:20+01:00	{"level":"debug","ts":1673950520.038858,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"mimir-1:8080","duration":0.008609509,"request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Encoding":["snappy"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Forwarded-For":["172.18.0.1"],"X-Forwarded-Proto":["https"],"X-Scope-Orgid":["mimir"],"Content-Type":["application/x-protobuf"],"User-Agent":["Prometheus/2.37.4"],"X-Forwarded-Host":["mimir.example.com"],"Content-Length":["58949"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"headers":{"Content-Length":["0"],"Date":["Tue, 17 Jan 2023 10:15:20 GMT"]},"status":200}
2023-01-17T11:15:20+01:00	{"level":"debug","ts":1673950520.0301821,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"mimir-1:8080","total_upstreams":3}
2023-01-17T11:15:15+01:00	{"level":"debug","ts":1673950515.04695,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"mimir-2:8080","duration":0.030221084,"request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"User-Agent":["Prometheus/2.37.4"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Scope-Orgid":["mimir"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["mimir.example.com"],"Content-Type":["application/x-protobuf"],"Content-Encoding":["snappy"],"Content-Length":["19069"],"X-Forwarded-For":["172.18.0.1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"error":"dial tcp: lookup mimir-2 on 127.0.0.11:53: server misbehaving"}
2023-01-17T11:15:15+01:00	{"level":"info","ts":"2023-01-17T10:15:15.025Z","logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Length":["20064"],"X-Scope-Orgid":["mimir"],"Content-Encoding":["snappy"],"Content-Type":["application/x-protobuf"],"User-Agent":["Prometheus/2.37.4"],"X-Prometheus-Remote-Write-Version":["0.1.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"user_id":"","duration":0.006742751,"size":0,"status":200,"resp_headers":{"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Date":["Tue, 17 Jan 2023 10:15:15 GMT"],"Content-Length":["0"]}}
2023-01-17T11:15:15+01:00	{"level":"debug","ts":1673950515.0251415,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"mimir-3:8080","duration":0.006480216,"request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Scope-Orgid":["mimir"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["mimir.example.com"],"Content-Length":["20064"],"Content-Encoding":["snappy"],"Content-Type":["application/x-protobuf"],"User-Agent":["Prometheus/2.37.4"],"X-Forwarded-For":["172.18.0.1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"headers":{"Date":["Tue, 17 Jan 2023 10:15:15 GMT"],"Content-Length":["0"]},"status":200}
2023-01-17T11:15:15+01:00	{"level":"debug","ts":1673950515.0185485,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"mimir-3:8080","total_upstreams":3}
2023-01-17T11:15:15+01:00	{"level":"debug","ts":1673950515.0166483,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"mimir-2:8080","total_upstreams":3}
2023-01-17T11:15:12+01:00	{"level":"info","ts":"2023-01-17T10:15:12.944Z","logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Encoding":["snappy"],"Content-Type":["application/x-protobuf"],"User-Agent":["Prometheus/2.37.4"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Scope-Orgid":["mimir"],"Content-Length":["119751"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"user_id":"","duration":0.02324268,"size":0,"status":200,"resp_headers":{"Alt-Svc":["h3=\":443\"; ma=2592000"],"Date":["Tue, 17 Jan 2023 10:15:12 GMT"],"Content-Length":["0"],"Server":["Caddy"]}}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.944365,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"mimir-1:8080","duration":0.023062001,"request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"X-Forwarded-Proto":["https"],"Content-Type":["application/x-protobuf"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"Content-Length":["119751"],"Content-Encoding":["snappy"],"X-Forwarded-For":["172.18.0.1"],"User-Agent":["Prometheus/2.37.4"],"X-Scope-Orgid":["mimir"],"X-Forwarded-Host":["mimir.example.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"headers":{"Date":["Tue, 17 Jan 2023 10:15:12 GMT"],"Content-Length":["0"]},"status":200}
2023-01-17T11:15:12+01:00	{"level":"info","ts":"2023-01-17T10:15:12.940Z","logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Encoding":["snappy"],"Content-Type":["application/x-protobuf"],"User-Agent":["Prometheus/2.37.4"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Scope-Orgid":["mimir"],"Content-Length":["116491"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"user_id":"","duration":0.02442146,"size":0,"status":200,"resp_headers":{"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Date":["Tue, 17 Jan 2023 10:15:12 GMT"],"Content-Length":["0"]}}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.940705,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"mimir-3:8080","duration":0.024193038,"request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Encoding":["snappy"],"X-Scope-Orgid":["mimir"],"Content-Length":["116491"],"X-Forwarded-For":["172.18.0.1"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["mimir.example.com"],"Content-Type":["application/x-protobuf"],"User-Agent":["Prometheus/2.37.4"],"X-Prometheus-Remote-Write-Version":["0.1.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"headers":{"Date":["Tue, 17 Jan 2023 10:15:12 GMT"],"Content-Length":["0"]},"status":200}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.9229634,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"mimir-2:8080","duration":0.021805588,"request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Length":["29350"],"X-Forwarded-For":["172.18.0.1"],"X-Forwarded-Proto":["https"],"Content-Type":["application/x-protobuf"],"Content-Encoding":["snappy"],"X-Scope-Orgid":["mimir"],"X-Forwarded-Host":["mimir.example.com"],"User-Agent":["Prometheus/2.37.4"],"X-Prometheus-Remote-Write-Version":["0.1.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"error":"dial tcp: lookup mimir-2 on 127.0.0.11:53: server misbehaving"}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.9228976,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"mimir-2:8080","duration":0.024956551,"request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Length":["31867"],"Content-Type":["application/x-protobuf"],"X-Forwarded-Host":["mimir.example.com"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Scope-Orgid":["mimir"],"X-Forwarded-For":["172.18.0.1"],"X-Forwarded-Proto":["https"],"Content-Encoding":["snappy"],"User-Agent":["Prometheus/2.37.4"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"error":"dial tcp: lookup mimir-2 on 127.0.0.11:53: server misbehaving"}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.9212196,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"mimir-1:8080","total_upstreams":3}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.9164207,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"mimir-3:8080","total_upstreams":3}
2023-01-17T11:15:12+01:00	{"level":"info","ts":"2023-01-17T10:15:12.912Z","logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Type":["application/x-protobuf"],"Content-Length":["37835"],"User-Agent":["Prometheus/2.37.4"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Scope-Orgid":["mimir"],"Content-Encoding":["snappy"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"user_id":"","duration":0.011408476,"size":0,"status":200,"resp_headers":{"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Content-Length":["0"],"Date":["Tue, 17 Jan 2023 10:15:12 GMT"]}}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.9124403,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"mimir-1:8080","duration":0.011056799,"request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Type":["application/x-protobuf"],"X-Forwarded-Proto":["https"],"User-Agent":["Prometheus/2.37.4"],"Content-Encoding":["snappy"],"Content-Length":["37835"],"X-Forwarded-For":["172.18.0.1"],"X-Forwarded-Host":["mimir.example.com"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Scope-Orgid":["mimir"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"headers":{"Date":["Tue, 17 Jan 2023 10:15:12 GMT"],"Content-Length":["0"]},"status":200}
2023-01-17T11:15:12+01:00	{"level":"info","ts":"2023-01-17T10:15:12.912Z","logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"User-Agent":["Prometheus/2.37.4"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Scope-Orgid":["mimir"],"Content-Encoding":["snappy"],"Content-Type":["application/x-protobuf"],"Content-Length":["37897"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"user_id":"","duration":0.012061571,"size":0,"status":200,"resp_headers":{"Alt-Svc":["h3=\":443\"; ma=2592000"],"Date":["Tue, 17 Jan 2023 10:15:12 GMT"],"Content-Length":["0"],"Server":["Caddy"]}}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.911698,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"mimir-3:8080","duration":0.01161726,"request":{"remote_ip":"172.18.0.1","remote_port":"51046","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"X-Scope-Orgid":["mimir"],"Content-Encoding":["snappy"],"X-Forwarded-Host":["mimir.example.com"],"Content-Type":["application/x-protobuf"],"Content-Length":["37897"],"User-Agent":["Prometheus/2.37.4"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Forwarded-For":["172.18.0.1"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"headers":{"Date":["Tue, 17 Jan 2023 10:15:12 GMT"],"Content-Length":["0"]},"status":200}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.9011023,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"mimir-1:8080","total_upstreams":3}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.9011018,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"mimir-2:8080","total_upstreams":3}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.8999825,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"mimir-3:8080","total_upstreams":3}
2023-01-17T11:15:12+01:00	{"level":"debug","ts":1673950512.8977985,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"mimir-2:8080","total_upstreams":3}
Tested with nginx load balancer and it works, that’s exactly what I want to do with Caddy.
events {
    worker_connections 1024;
http {
    upstream backend {
        server mimir-1:8080 max_fails=1 fail_timeout=1s;
        server mimir-2:8080 max_fails=1 fail_timeout=1s;
        server mimir-3:8080 max_fails=1 fail_timeout=1s backup;
    server {
        listen 9009;
        access_log /dev/null;
        location / {
            proxy_pass http://backend;
Remove the lb_try_interval 250s or set it to something closer to its default value (250ms)
You are waiting 250 seconds before trying the next upstream if one fails
Hi Emily,
thanks for the swift feedback, your hint, that helped me! I still have one problem, if I kill one of the 3 containers, then the Mimir is reachable, but if I kill two containers the GUI of Mimir is reachable, but no data arrives at Grafana Mimir. I get status code 502.
You’ll need to show your logs again. It’s impossible to know what’s going on without more evidence.
You are absolutely right, attached are the Caddy logs:
2023-01-18 11:07:39
{"level":"error","ts":"2023-01-18T10:07:39.841Z","logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"172.20.1.244","remote_port":"44710","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Encoding":["snappy"],"Content-Type":["application/x-protobuf"],"User-Agent":["Prometheus/2.36.0"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Scope-Orgid":["mimir"],"Content-Length":["19604"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"user_id":"","duration":0.271081433,"size":0,"status":502,"resp_headers":{"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"]}}
2023-01-18 11:07:39
{"level":"error","ts":1674036459.840877,"logger":"http.log.error.log0","msg":"readfrom tcp 172.18.0.3:52374->172.18.0.9:8080: body closed by handler","request":{"remote_ip":"172.20.1.244","remote_port":"44710","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Encoding":["snappy"],"Content-Type":["application/x-protobuf"],"User-Agent":["Prometheus/2.36.0"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Scope-Orgid":["mimir"],"Content-Length":["19604"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"duration":0.271081433,"status":502,"err_id":"4nzufy4r5","err_trace":"reverseproxy.statusError (reverseproxy.go:1271)"}
2023-01-18 11:07:39
{"level":"debug","ts":1674036459.8404462,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"mimir-3:8080","duration":0.001081215,"request":{"remote_ip":"172.20.1.244","remote_port":"44710","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"Content-Type":["application/x-protobuf"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Forwarded-For":["172.20.1.244"],"X-Scope-Orgid":["mimir"],"Content-Length":["19604"],"Content-Encoding":["snappy"],"User-Agent":["Prometheus/2.36.0"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["mimir.example.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"error":"readfrom tcp 172.18.0.3:52374->172.18.0.9:8080: body closed by handler"}
2023-01-18 11:07:39
{"level":"debug","ts":1674036459.839271,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"mimir-3:8080","total_upstreams":3}
2023-01-18 11:07:39
{"level":"debug","ts":1674036459.5887415,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"mimir-2:8080","duration":0.018775056,"request":{"remote_ip":"172.20.1.244","remote_port":"44710","proto":"HTTP/2.0","method":"POST","host":"mimir.example.com","uri":"/api/v1/push","headers":{"X-Scope-Orgid":["mimir"],"Content-Length":["19604"],"Content-Encoding":["snappy"],"User-Agent":["Prometheus/2.36.0"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["mimir.example.com"],"Content-Type":["application/x-protobuf"],"X-Prometheus-Remote-Write-Version":["0.1.0"],"X-Forwarded-For":["172.20.1.244"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"error":"dial tcp: lookup mimir-2 on 127.0.0.11:53: server misbehaving"}
2023-01-18 11:07:39
{"level":"debug","ts":1674036459.5698311,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"mimir-2:8080","total_upstreams":3}
2023-01-18 11:07:38
{"level":"error","ts":1674036458.420768,"logger":"http.log.error.log0","msg":"dial tcp: lookup mimir-1 on 127.0.0.11:53: server misbehaving","request":{"remote_ip":"172.20.1.244","remote_port":"61484","proto":"HTTP/2.0","method":"GET","host":"mimir.example.com","uri":"/static/mimir-icon.png","headers":{"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"],"Accept":["image/avif,image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Mode":["no-cors"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Sec-Fetch-Dest":["image"],"Referer":["https://mimir.example.com/memberlist"],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Sec-Ch-Ua":["\"Not?A_Brand\";v=\"8\", \"Chromium\";v=\"108\", \"Google Chrome\";v=\"108\""]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"duration":1.095027931,"status":502,"err_id":"htarfkeid","err_trace":"reverseproxy.statusError (reverseproxy.go:1271)"}
2023-01-18 11:07:38
{"level":"error","ts":"2023-01-18T10:07:38.420Z","logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"172.20.1.244","remote_port":"61484","proto":"HTTP/2.0","method":"GET","host":"mimir.example.com","uri":"/static/mimir-icon.png","headers":{"Sec-Ch-Ua-Mobile":["?0"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"],"Accept":["image/avif,image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Mode":["no-cors"],"Sec-Ch-Ua":["\"Not?A_Brand\";v=\"8\", \"Chromium\";v=\"108\", \"Google Chrome\";v=\"108\""],"Sec-Ch-Ua-Platform":["\"Windows\""],"Sec-Fetch-Dest":["image"],"Referer":["https://mimir.example.com/memberlist"],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mimir.example.com"}},"user_id":"","duration":1.095027931,"size":0,"status":502,"resp_headers":{"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"]}}
Can you share your Caddyfile and logs with debug logging (just like in your opening post) again?
What did you set lb_try_interval to now?
It describes the total amount spent load balancing a request, so it should be less than $lb_try_duration * $retries.
If you don’t feel like playing around with durations, just use lb_retries:
mimir.example.com {
	import logconsole
	reverse_proxy {
		to mimir-1:8080
		to mimir-2:8080
		to mimir-3:8080
		lb_retries 2
Hello Emily,
with the configuration, i can reach the state of nginx. That helps me. Many thanks for your support.
caddy conf
mimir.example.com {
         import logconsole
         reverse_proxy * {
                 to mimir-1:8080
                 to mimir-2:8080
                 to mimir-3:8080
                 lb_try_duration 1s
                 max_fails 1
Nginx conf
events {
http {
    upstream backend {
    server {
        listen 9009;
        location / {
