I have a docker container with Caddy and a docker container with MongoDB
a domain mongodb.notepad.be points to my caddyserver public ip
the certificate is ok, but when i connect with MongoDB Compass and set tls=true
I get an error
Client network socket disconnected before secure TLS connection was established
Caddy 2.8.4-Alpine
caddy image from hub.docker.com
Host Debian GNU/Linux 12 (bookworm)
Docker version 27.0.2, build 912c1dd
docker run -d -p 80:80 -p 443:443 -p 27017:27017 -p 443:443/udp \
--network mongodbnet \
--restart unless-stopped \
--name caddy284 \
-v caddyconfig:/config \
-v caddydata:/data \
caddy:2.8.4-alpine \
caddy run --config /config/caddy/macmini1-caddy.json
"apps": {
"layer4": {
"servers": {
"localhost": {
"listen": [":27017"],
"routes": [
"match": [
"tls": { "sni": ["mongodb.notepad.be"] }
"handle": [
"handler": "proxy",
"upstreams": [
"dial": ["192.168.1.203:27017"]
"http": {
"servers": {
"localhost": {
"listen": [":443"],
"routes": [
"handle": [
"handler": "reverse_proxy",
"transport": {
"protocol": "http"
"upstreams": [
"dial": "hub:7000"
"match": [
"host": ["hub.notepad.be"]
"handle": [
"transport": {
"protocol": "http"
"upstreams": [
"dial": "apipdf:5300"
"match": [
"host": ["apipdf.notepad.be"]
"handle": [
"transport": {
"protocol": "http"
"upstreams": [
"dial": "backoffice:5100"
"match": [
"host": ["my.notepad.be"]
"tls": {
"automation": {
"policies": [
"issuers": [
"email": "herman@vanlooveren.com",
"module": "acme"
"certificates": {
"automate": ["mongodb.notepad.be", "hub.notepad.be", "apipdf.notepad.be", "my.notepad.be"]
