1. Output of caddy version
I am intending on using my Linux-based PC as a persistent online server for FoundryVTT. I am currently getting my system configured
Ubuntu 22.04 1 LTS
sudo service caddy start
sudo service caddy restart
sudo service caddy stop
# Unsure of what to put here as this is
# my first experience in trying to run Linux
# This replaces the existing content in /etc/caddy/Caddyfile
# A CONFIG SECTION FOR YOUR IP AND HOSTNAME
default_sni 192.168.1.242
192.168.1.242 {
# PROXY ALL REQUEST TO PORT 30000
tls internal
reverse_proxy localhost:30000
encode zstd gzip
or10nfoundry.thenest.org {
encode zstd gzip
Simply put, I am setting up my Linux system to be a persistent
e[0;1;31m×e[0m caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: e[0;1;31mfailede[0m (Result: exit-code) since Sun 2022-11-20 16:49:58 EST; 7min ago
Process: 7698 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile e[0;1;31m(code=exited, status=1/FAILURE)e[0m
Main PID: 7698 (code=exited, status=1/FAILURE)
Status: "loading new config: http app module: start: listening on :80: listen tcp :80: bind: address already in use"
CPU: 51ms
Nov 20 16:49:58 or10n-linuxserver caddy[7698]: {"level":"info","ts":1668980998.7754562,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Nov 20 16:49:58 or10n-linuxserver caddy[7698]: {"level":"info","ts":1668980998.7755146,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Nov 20 16:49:58 or10n-linuxserver caddy[7698]: {"level":"info","ts":1668980998.7755513,"logger":"tls","msg":"finished cleaning storage units"}
Nov 20 16:49:58 or10n-linuxserver caddy[7698]: {"level":"info","ts":1668980998.7755766,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
Nov 20 16:49:58 or10n-linuxserver caddy[7698]: {"level":"info","ts":1668980998.7756886,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Nov 20 16:49:58 or10n-linuxserver caddy[7698]: {"level":"info","ts":1668980998.775784,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0000a2e00"}
Nov 20 16:49:58 or10n-linuxserver caddy[7698]: Error: loading initial config: loading new config: http app module: start: listening on :80: listen tcp :80: bind: address already in use
Nov 20 16:49:58 or10n-linuxserver systemd[1]: e[0;1;39me[0;1;31me[0;1;39mcaddy.service: Main process exited, code=exited, status=1/FAILUREe[0m
Nov 20 16:49:58 or10n-linuxserver systemd[1]: e[0;1;38;5;185me[0;1;39me[0;1;38;5;185mcaddy.service: Failed with result 'exit-code'.e[0m
Nov 20 16:49:58 or10n-linuxserver systemd[1]: e[0;1;31me[0;1;39me[0;1;31mFailed to start Caddy.e[0m
I’m not really entirely sure what else I can try at this point. This is already the second time I reinstalled Ubuntu to start fresh because of an unrelated issue. Caddy was working fine for me the last time I attempted this and I did not deviate from a tutorial I’d been following.
(Recommended Linux installation for FoundryVTT) Recommended Linux Installation Guide | Foundry VTT Community Wiki
