1. Caddy version:
docker image: caddy:2.3.0-alpine
OS: Ubuntu 22.04.1 LTS x86_64
Docker version 20.10.22, build 3a2c30b
docker-compose version 1.29.2, build unknown
docker-compose up
c. docker-compose.yaml file:
#docker-compose.yaml
version: '3'
proxy:
service1:
image: nginx:latest
expose:
- "8080"
service2:
image: httpd:latest
expose:
- "8081"
hostname:80 {
reverse_proxy service1:8080
reverse_proxy service2:8081
I am implementing reverse proxy using caddy in docker container. i have docker-compose file in which i specifed three service caddy, nginx, httpd. i also configured caddyfile in which i redirected my request to servers. when i run ‘$docker-compose up’ all the containers working perfectlly fine. but when i go to
http://localhost/ - show blank white page
http://localhost:8080/ - this site cant be reach
http://localhost:8081/ - this site cant be reach
nginx_container_IP - show nginx page
httpd_container_IP - show httpd page
4.caddy_container_logs:
{"level":"info","ts":1675247772.029432,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"} {"level":"info","ts":1675247772.033348,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]} {"level":"info","ts":1675247772.033649,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80} {"level":"info","ts":1675247772.0337453,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002f52d0"} {"level":"info","ts":1675247772.0342908,"logger":"tls","msg":"cleaned up storage units"} {"level":"info","ts":1675247772.034485,"msg":"autosaved config","file":"/config/caddy/autosave.json"} {"level":"info","ts":1675247772.0345104,"msg":"serving initial configuration"}
ChatGPT
